Eclipse crashes by typing $ in PHP file [message #896778] |
Thu, 19 July 2012 13:11  |
I was updating some php files in an older eclipse installation and the application crashed. I am on linux (slackware64-current) running the openjdk and thought maybe I had to upgrade eclipse.
I went and installed Juno, got some PDT on it and it crashed again; always after typing $ (and nothing else, like ?!"£%^&(){}[] ) and just after a completion hint pops up.
I have installed eclipse with PHP twice now, also as proposed on http://dev.eclipse.org/mhonarc/lists/pdt-dev/msg02126.html
The crash always occurs after the PDT install (from inside eclipse), not before i.e. the $ in a text file is accepted.
No problems when doing the same on Netbeans (although the fonts look ugly I have to use that now) or typing $ into another JAVA application (like Violet or CLC sequence viewer).
Thus definitely PHP/PDT linked.
Am I the only one experiencing this???
Thanks for anyone with a good tip,
rob
Some collected log-files attached.....
FUDForum. Page generated in 0.06350 seconds
