Creating Connections Programtically [message #896908] |
Fri, 20 July 2012 08:00  |
Similar topic has been discussed previously in here[http://www.eclipse.org/forums/index.php/m/896890/#msg_896890]. However I am not able to get it right. Pointers will be highly appreciatd.
Problem Description:
My EMF based domain model (partial) is here .
I have Task nodes and tasks are connected by Links, sounds simple!!
I can create Tasks nodes and show them on Graphiti editor programatically but the problem is in creating links between tasks.
In the following code (within a command that will be executed from some context menu in UI - eclipse RCP), I am trying to create two Task nodes, and a Link to connect these two tasks.
protected void doExecute() {
// Get all Tasks and links to the given diagram
List tasks = new ArrayList();
OrderedTask t1 = IdmmodelFactory.eINSTANCE.createOrderedTask();
t1.setName("t1");
tasks.add(t1);
OrderedTask t2 = IdmmodelFactory.eINSTANCE.createOrderedTask();
t2.setName("t2");
tasks.add(t2);
List links = new ArrayList();
OrderLink l1 = IdmmodelFactory.eINSTANCE.createOrderLink();
l1.setName("");
l1.setTarget(t2);
t1.getOutgoingLinks().add(l1);
links.add(l1);
// Create the diagram and its file
Diagram diagram = Graphiti.getPeCreateService().createDiagram("sapidmtaskflow", diagramName, true);
diagramFile = createResourceFile(diagramName) ;
URI uri = URI.createPlatformResourceURI(diagramFile.getFullPath().toString(), true);
createdResource = editingDomain.getResourceSet().createResource(uri);
createdResource.getContents().add(diagram);
// create/get resource and save diagram to it
IDiagramTypeProvider dtp = GraphitiUi.getExtensionManager().createDiagramTypeProvider(diagram,
"com.sap.idm.ic.rcp.graphiti.diagrams.TaskFlowDiagramTypeProvider");
IFeatureProvider featureProvider = dtp.getFeatureProvider();
// Add all tasks to diagram
int x = 20;
int y = 20;
for (int i = 0; i < tasks.size(); i++) {
// Create the context information
AddContext addContext = new AddContext();
addContext.setNewObject(tasks.get(i));
addContext.setTargetContainer(diagram);
addContext.setX(x);
addContext.setY(y);
x = x + 20;
y = y + 20;
IAddFeature addFeature = featureProvider.getAddFeature(addContext);
if (addFeature.canAdd(addContext)) {
addFeature.add(addContext);
// if I commenteded out rest of the code, I can see two task nodes on the editor..fine
// if I add the following code, the following exception occurs...PROBLEM!!!
// org.eclipse.emf.common.util.WrappedException: An exception was ignored during command execution
PictogramLink plink = PictogramsFactory.eINSTANCE.createPictogramLink();
diagram.setLink(plink);
for (int i = 0; i < links.size(); i++) {
OrderLink link = (OrderLink) links.get(i);
plink.getBusinessObjects().add(link);
CreateConnectionContext createContext = new CreateConnectionContext();
Task src = link.getSource();
Task tar = link.getTarget();
ICreateConnectionFeature[] createCFeatureList = featureProvider.getCreateConnectionFeatures();
ICreateConnectionFeature createCFeature = createCFeatureList[0];
EList<PictogramLink> plinks = diagram.getPictogramLinks();
createContext.setSourcePictogramElement(getAnchorFromPE(plinks, src));
createContext.setSourceAnchor(createContext.getSourceAnchor());
createContext.setTargetPictogramElement(getAnchorFromPE(plinks, tar));
createContext.setTargetAnchor(createContext.getTargetAnchor());
if(createCFeature.canCreate(createContext)){
createCFeature.create(createContext);
private PictogramElement getAnchorFromPE(List plinks, Task task){
PictogramElement a = null;
for (int i = 0; i < plinks.size(); i++) {
PictogramLink p = (PictogramLink) plinks.get(i);
List list = p.getBusinessObjects();
for (int j = 0; j < list.size(); j++) {
EObject eobj = (EObject) list.get(i);
if(eobj instanceof Task){
Task t = (Task)eobj;
if(t.getName().equalsIgnoreCase(task.getName())){
return p.getPictogramElement();
return a;
-Surya
Attachment: tasklink.bmp
(Size: 388.57KB, Downloaded 729 times)
Attachment: tasklink.gif
(Size: 23.25KB, Downloaded 270 times)
FUDForum. Page generated in 0.04989 seconds
