Different test results between GUI Jubula and test executor via command line [message #896221] |
Tue, 17 July 2012 11:53  |
I was trying to run test executor using a configuration file, and after the executor finished doing all the test cases, several tests fail. After taking a closer look, I noticed that all of the fail cases were "ub_app_executeExternalCommand" that I had in different parts of my entire test. The reason according to given results was because the command was not found. I checked the path of my command (which exists), I tried using quotes (") and many other things, but failing to have the desired results.
Then, what I decided to do was to run the tests via GUI. Surprisingly, all the test cases were successfully completed. I did not have any error. Is there any type of bug on the command line or am I missing something?
I appreciate the help in advance.
Oscar Trejo.
FUDForum. Page generated in 0.22944 seconds
