cannot use eclipselink 2.x [message #896754] |
Thu, 19 July 2012 11:28  |
when I new a JPA project, select the platform, only 1.x is shown, why?
the sequence is attached as image 1-5.
In step 2, I select weblogic 11g as runtime, in step 3, I select default configuration for weblogic 11g, then in step 5, no eclipse 2.x is allowed to choose.
I know weblogic 11g (10.3.4) default is using jpa 1 but can manual enable to support jpa2, and I already manual enable it. But dali still not allow me to choose eclipselink 2.x in step 5, why?
Attachment: 1.JPG
(Size: 35.02KB, Downloaded 676 times)
Attachment: 2.JPG
(Size: 59.82KB, Downloaded 633 times)
Attachment: 3.JPG
(Size: 58.31KB, Downloaded 517 times)
Attachment: 4.JPG
(Size: 59.46KB, Downloaded 594 times)
Attachment: 5.JPG
(Size: 53.73KB, Downloaded 540 times)
Re: cannot use eclipselink 2.x [message #896833 is a reply to message #896800] |
Thu, 19 July 2012 22:11   |
sorry, I am very new to Dali and eclipselink.
After press the modify button, jpa6.jpg is shown, and there is still no jpa 2.0 to choose.
jpa7.jpg shown my current dali version.
in the link
http://docs.oracle.com/cd/E21764_01/web.1111/e13720/using_toplink.htm#CIHDGHFE
weblogic 10.3.4 should support jpa 2.0 after manual install the patch.
2)
if choose tomcat 6.0 as the target runtime as shown in jpa8.jpg, then in platform (jpa9.jpg), I can choose Eclipselink 2.0.x, and in JPA Implementation, I need download Eclipse 2.1.3 if my eclipse version is Helios?
3)
Any tutorial for learning EclipseLink + Dali + JPA recommended?
Attachment: jpa6.jpg
(Size: 70.61KB, Downloaded 559 times)
Attachment: jpa7.jpg
(Size: 135.60KB, Downloaded 555 times)
Attachment: jpa8.jpg
(Size: 64.93KB, Downloaded 624 times)
Attachment: jpa9.jpg
(Size: 185.96KB, Downloaded 550 times)
Re: cannot use eclipselink 2.x [message #896966 is a reply to message #896833] |
Fri, 20 July 2012 11:10   |
tong123123 tong123123 wrote on Thu, 19 July 2012 22:11sorry, I am very new to Dali and eclipselink.
in the link
2)
3)
See Paul's comment regarding the version field. You are correct that WLS 10.3.4 will support JPA 2.0 after patching.
2) You should probably be basing your tooling needs around the version of EclipseLink that you need to use. Is there a reason you cannot move beyond the Eclipse Helios version? Helios is getting pretty old at this point.
3) The Dali website links to a number of How-To demos and also has a tutorial that may be helpful. The tutorial is somewhat out of date, but the concepts should be the same. Look on the right hand side of the screen for link to documentation, etc. http://eclipse.org/webtools/dali/
Re: cannot use eclipselink 2.x [message #897431 is a reply to message #897363] |
Tue, 24 July 2012 02:47   |
1) What does the screen referenced in the blog look like now? Please attach a screen capture.
as attached in jpa11, jpa12, jpa13AfterInstall, in jpa13AfterInstall, although already press the server extension by clicking the install link, the link still appear and active.
2)attach a screen capture of the facets selection screen with the runtimes tab on the right selected and the weblogic server that you are targeting selected
as shown in jpa14.jpg, no jpa 2.0 is observed in the list.
Attachment: jpa11.jpg
(Size: 43.17KB, Downloaded 556 times)
Attachment: jpa12.jpg
(Size: 20.91KB, Downloaded 562 times)
Attachment: jpa13AfterInstall.jpg
(Size: 42.98KB, Downloaded 530 times)
Attachment: jpa14.jpg
(Size: 67.35KB, Downloaded 570 times)
Re: cannot use eclipselink 2.x [message #898579 is a reply to message #898221] |
Thu, 26 July 2012 12:49  |
If you use Eclipse to add JPA 2.0 support to WLS, you do not need to follow commEnv.cmd instructions which provide an alternate way of doing this that isn't compatible with Eclipse.
- Konstantin
FUDForum. Page generated in 0.06238 seconds
