Home » Archived » Buckminster » Adding source features to category.xml
Adding source features to category.xml [message #896250] Tue, 17 July 2012 13:22 Go to next message
Buckminster already generates source plugins and features which is nice!
Now I'd like to add the source features to my category.xml so that
they appear as belonging to the main category (while by default they
appear as non categorized).
In order to do that I added to my category.xml besides my main feature,
e.g.,
<feature id="my.proj.feature">
<category name="mycategory"/>
</feature>
also the source feature (which is not in the workspace, it is actually
generated only by Buckminster):
<feature id="my.proj.feature.source">
</feature>
However, the generated site.p2 still does not show the source feature in
the category...
am I doing something wrong?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Adding source features to category.xml [message #896313 is a reply to message #896250] Tue, 17 July 2012 22:54 Go to previous messageGo to next message
Hi Lorenzo,
I think the source feature will be named my.proj.source.feature rather than my.proj.feature.source. In other respects I
don't see anything wrong with your setup. We're doing the same thing in Buckminster and it works as expected.
HTH,
- thomas
On 07/17/2012 07:22 PM, Lorenzo Bettini wrote:
> Hi
> Buckminster already generates source plugins and features which is nice! Now I'd like to add the source features to my
> category.xml so that they appear as belonging to the main category (while by default they appear as non categorized).
> In order to do that I added to my category.xml besides my main feature, e.g.,
> </feature>
> also the source feature (which is not in the workspace, it is actually generated only by Buckminster):
> </feature>
> However, the generated site.p2 still does not show the source feature in the category...
> thanks in advance
> Lorenzo
Re: Adding source features to category.xml [message #896378 is a reply to message #896313] Wed, 18 July 2012 04:39 Go to previous messageGo to next message
I think <feature-name>.source is the correct name.
For example following works for me:
<site>
	<feature id="org.xtext.example.mydsl.sdk" version="0.0.0">
		<category name="main"/>
	</feature>
	<feature id="org.xtext.example.mydsl.sdk.source" version="0.0.0">
		<category name="main.source"/>
	</feature>
   <category-def name="main" label="Mydsl"/>
   <category-def name="main.source" label="Source for Mydsl"/>
</site>
You can also look into the metadata of the generated p2 repositoy to track down what is going wrong.
Re: Adding source features to category.xml [message #896394 is a reply to message #896378] Wed, 18 July 2012 05:23 Go to previous messageGo to next message
That depends actually. If the name ends with .feature, then the name of the source feature will become .source.feature
- thomas
> <site>
> </feature>
> </feature>
> </site>
Re: Adding source features to category.xml [message #896397 is a reply to message #896394] Wed, 18 July 2012 05:37 Go to previous messageGo to next message
Very interesting, there is probably a very good reason for such kind of behavior.
That may be a bit confusing for buckminster noobs Smile
Re: Adding source features to category.xml [message #896406 is a reply to message #896397] Wed, 18 July 2012 06:05 Go to previous messageGo to next message
> That may be a bit confusing for buckminster noobs :)
At the time when this was implemented, this naming scheme seemed to be very common. Hence the logic that implements it.
Some new naming rules were established when p2 came around though, which I think has made people move away from the
older habit of using a .feature suffix for features. P2 adds '.feature.group' and 'feature.jar' to the respective p2
IU's and names ending with .feature.feature.group and feature.feature.jar might seem a bit strange.
- thomas
Re: Adding source features to category.xml [message #896475 is a reply to message #896378] Wed, 18 July 2012 09:41 Go to previous messageGo to next message
> <site>
> </feature>
> </feature>
> </site>
Hi Dennis
I was about to bring the xtext example (which I've been using
extensively for my Xtext projects) as a counter example which was
working :) I started from that example to put the source feature in my
category and I was astonished it was not working
I'll try the other source.feature in my other project (not related to
Xtext) which actually ends with .feature
thanks
Lorenzo
Re: Adding source features to category.xml [message #896628 is a reply to message #896394] Thu, 19 July 2012 04:11 Go to previous messageGo to next message
yes, using .source.feature works! :)
thanks
Lore
> - thomas
>> <?xml version="1.0" encoding="UTF-8"?>
>> <site>
>> </feature>
>> </feature>
>> </site>
Re: Adding source features to category.xml [message #896629 is a reply to message #896406] Thu, 19 July 2012 04:11 Go to previous messageGo to next message
>> of behavior.
> very common. Hence the logic that implements it. Some new naming rules
> people move away from the older habit of using a .feature suffix for
> p2 IU's and names ending with .feature.feature.group and
So, it would be better NOT to add .feature to feature's id?
cheers
Lorenzo
Re: Adding source features to category.xml [message #896632 is a reply to message #896629] Thu, 19 July 2012 04:22 Go to previous message
It doesn't matter really. Your choice.
- thomas
Previous Topic:Eclipse-SourceReferences (take two)
Next Topic:No resolve against targetplatform
Current Time: Fri Jul 18 18:39:35 EDT 2025
Powered by FUDForum. Page generated in 0.37072 seconds
