Home » Newcomers » Newcomers » How can I change jvm which eclipse runs on?
How can I change jvm which eclipse runs on? [message #89149] Tue, 26 July 2005 02:58 Go to next message
Originally posted by: mjb4567.yahoo.com
In other words, how can I change the Hotspot VM that the eclipse program
uses, as opposed to the version of java used to check, compile or run the
user program. Also how can I run eclipse on the interpreter instead of the
Hotspot VM. Is there a more stable amd64 java VM than Suns version?
The reason I ask is that eclipse keeps crashing with a HotSpot VM error. I
have downloaded java 1.5.0_04 to see if that fixes the problem but I don't
know how to switch to it.
I am running it on an amd64 machine, I have put full details of how I have
setup eclipse here:
http://www.euclideanspace.com/software/language/java/eclipse /
I have also included the full error message in the above page, the first
part is listed below.
Martin
# An unexpected error has been detected by HotSpot Virtual Machine:
# Internal Error (4E4D4554484F440E435050051D), pid=16725, tid=1091348832
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_03-b07 mixed mode)
--------------- T H R E A D ---------------
Current thread (0x00002aab067fa950): JavaThread "Java indexing" daemon
[_thread_in_Java, id=16754]
Re: How can I change jvm which eclipse runs on? [message #89662 is a reply to message #89149] Wed, 27 July 2005 11:24 Go to previous messageGo to next message
> the user program. Also how can I run eclipse on the interpreter instead
> of the Hotspot VM. Is there a more stable amd64 java VM than Suns version?
These Wiki pages should help you:
http://eclipsewiki.editme.com/RunningThePlatform
http://eclipsewiki.editme.com/StartupProblems
HTH,
Eric
Re: How can I change jvm which eclipse runs on? [message #89813 is a reply to message #89662] Wed, 27 July 2005 17:16 Go to previous messageGo to next message
Thanks very much, using the references you quoted, I tried the latest
version of Java but the VM is still crashing, do you know if others are
having problems usung eclipse with Linux amd64 VM, or is it just me?
Cheers, Martin
martin@linux:~> /usr/share/eclipse/eclipse -vm /usr/java/jdk1.5.0_04/bin/java
# Internal Error (4E4D4554484F440E4350500521), pid=15373, tid=1091348832
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_04-b05 mixed mode)
# An error report file with more information is saved as
hs_err_pid15373.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Re: How can I change jvm which eclipse runs on? [message #90028 is a reply to message #89813] Thu, 28 July 2005 10:19 Go to previous message
I can't say, but unless it is specifically stated as unsupported I'd be
surprised if no one has tried it.
You might try posting a new thread on the eclipse.platform group that
asks specifically about Linux on AMD 64-bit. Include your eclipse.exe
startup arguments, the JVM version info, and the error your get. Also
check to see if there is a .metadata/.log file in your workspace directory.
HTH,
Eric
Previous Topic:Simple to Java Project
Next Topic:why my program so slowly?
Current Time: Sat Nov 08 23:58:44 EST 2025
Powered by FUDForum. Page generated in 0.15112 seconds
