SWT Javadoc [message #895728] |
Sun, 15 July 2012 08:13  |
Where can I download the SWT Javadoc?
I installed Window Builder (which I think installed SWT), but there was
no Javadoc included.
I know there is an online Javadoc, but my development machine is not
connected, so I actually need a file.
Wojtek :-)
Re: SWT Javadoc [message #897042 is a reply to message #897019] |
Fri, 20 July 2012 19:01   |
David Wegener wrote :
> They are available in the Platform Plug-in Developers Guide which is
> available in the Help->Help Contents. They are also available indirectly as
> source from the swt plugins. You should get these automatically if you
> install the Eclipse Platform SDK.
Yes they are in the Eclipse Help. However there is no place I can point
the swt.jar/ properties/ java doc location to. Without this path
Eclipse does not popup Javadoc when you hover over a class/method. I
know I could use a URL, but my development machine is on a private LAN
not connected to the Internet.
My installation of Eclipse + Window Builder only had the Windows jar
file.
I did eventually learn that I could use the source, but then my
installation did not include that source. After rooting around the
Eclipse site I located an SWT jar which did include the source, I
downloaded it, pointed Eclipse at it, and now I have popup Javadoc.
It is not that I could not eventually solve this. It is that I spent
too much time searching the Web, reading other people's posts in
various forums, finding a solution, then searching the Eclipse sites.
Call me lazy, but could not a download link to the SWT Javadoc be
placed on the http://www.eclipse.org/swt/javadoc.php page?
Wojtek :-)
Re: SWT Javadoc [message #897045 is a reply to message #897042] |
Fri, 20 July 2012 19:54   |
>> indirectly as source from the swt plugins. You should get these
>> automatically if you install the Eclipse Platform SDK.
> the swt.jar/ properties/ java doc location to. Without this path Eclipse
> does not popup Javadoc when you hover over a class/method. I know I
> could use a URL, but my development machine is on a private LAN not
> My installation of Eclipse + Window Builder only had the Windows jar file.
> It is not that I could not eventually solve this. It is that I spent too
> much time searching the Web, reading other people's posts in various
> Call me lazy, but could not a download link to the SWT Javadoc be placed
If you install the Eclipse Platform SDK, it will automatically associate
the source with the SWT classes so the hover will be populated. The SDK
includes the source plugin.
Re: SWT Javadoc [message #897048 is a reply to message #897045] |
Sat, 21 July 2012 00:40   |
> If you install the Eclipse Platform SDK, it will automatically associate the
> source with the SWT classes so the hover will be populated. The SDK includes
> the source plugin.
Hmm, I downloaded "Eclipse IDE for Java Developers"
Because according to this page
http://www.eclipse.org/downloads/compare.php that package had what I
needed.
Wojtek :-)
Re: SWT Javadoc [message #1039224 is a reply to message #897048] |
Thu, 11 April 2013 19:20  |
Yeah. Wojtek is right. Getting this offline SWT javadoc to work is real PITA. I also don't know what is it with all secrecy around offline JAR or ZIP. Why it can't be made easy downloadable from main online javadoc page?
I don't know exact steps that Wojtek did, but here are mine (since I couldn't find them alltogether anywhere):
- download source for SWT from 'http://www.eclipse.org/swt/' (search for links near title "Releases")
(next few steps are taken from page on stackoverflow - looks like I'm not allowed to paste it since i'm new on this forum)
- Go to eclipse and load downloaded swt as existing project
- you'll find src.zip in that project
- unzip src.zip and copy the folder "org" (org\eclipse\swt...)
- paste that folder in src (inside the project)
- select org folder in eclipse then go to project >> generate javadocs
- If you're in windows you probably going to press on (Configure) to pick up the Javadoc.exe file it's in the C:\programFiles\java\jdk-xyz\bin\
- choose where you want to drop the doc files, next then finish
- go to the files and zip it (zip the files don't zip the folder which contains the files cause when you load the docs as archive and validate it won't see the index.html)
- right click on your project and choose 'properties'
- under 'java build path' go to 'libraries'
- here choose 'org.eclipse.swt.win32.win32.x86_3.100.1.v4236b.jar' and expand it with '+' key (or click on arrow on the left)
- doubleclick on 'javadoc location'
- choose 'javadoc in archive' and 'external file'
- under 'archive path' put into whole path to previously created javadoc ZIP file
FINALLY you have it!
FUDForum. Page generated in 0.08357 seconds
