New child menu entry for EMap and custom dialog [message #896093] |
Tue, 17 July 2012 05:02  |
I have modelled a StringToIntegerMap and trying to add a menu item for creating an entry.
My idea was to edit the generated method collectNewChildDescriptors and add following:
newChildDescriptors.add(createChildParameter(Package.Literals.STRING_TO_INTEGER_MAP__VALUE, Factory.eINSTANCE.create(Package.Literals.STRING_TO_INTEGER_MAP)));
But I get a NPE in the ActionBarContributor.
Can I add on that way an item?
[Updated on: Tue, 17 July 2012 11:29] by Moderator
Re: New child menu entry for EMap and custom dialog [message #896216 is a reply to message #896093] |
Tue, 17 July 2012 11:31   |
My command implementation with the InputDialog looks like following:
import org.eclipse.emf.common.command.Command;
import org.eclipse.emf.common.command.CommandWrapper;
import org.eclipse.emf.edit.command.CommandActionDelegate;
import org.eclipse.jface.dialogs.InputDialog;
import org.eclipse.ui.PlatformUI;
public class DefinitionCreateCommand extends CommandWrapper implements CommandActionDelegate {
public DefinitionCreateCommand(Command command) {
super(command);
public void execute() {
InputDialog dialog = new InputDialog(PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell(), "test",
"test message", "", null);
dialog.open();
public Object getImage() {
return ((CommandActionDelegate) super.command).getImage();
public String getText() {
return ((CommandActionDelegate) super.command).getText();
public String getToolTipText() {
return ((CommandActionDelegate) super.command).getToolTipText();
I have overwritten the method createCreateChildCommand with following content:
return new DefinitionCreateCommand(super.createCreateChildCommand(domain, owner, feature, value, index, collection));
It works so long, but how can I pass the result back?
Re: New child menu entry for EMap and custom dialog [message #896340 is a reply to message #896216] |
Wed, 18 July 2012 02:51   |
Command.getResult generally does the trick, after the command has been
executed.
> super(command);
> @Override
> "test",
> dialog.open();
> @Override
> @Override
> @Override
> content:
> return new
Re: New child menu entry for EMap and custom dialog [message #896505 is a reply to message #896501] |
Wed, 18 July 2012 10:59  |
Yes, that seems practical.
On 18/07/2012 4:54 PM, Missing name Mising name wrote:
> In general, is it a praticable way to create my own extension point
> for such an idea?
> I would create one and integrate it into the contributor class, so I
> can add my own action for special new child actions.
FUDForum. Page generated in 0.10770 seconds
