Home » Eclipse Projects » EclipseLink » @MappedSuperclass with Generic types(java.lang.IndexOutOfBoundsException)
@MappedSuperclass with Generic types [message #896422] Wed, 18 July 2012 07:04 Go to next message
Hi I'm using EclipseLink for testing purpose with Arquillian 1.0.1.Final & glassfish embedded all 3.1.2
When running the test I get an error that the Predeployment of my PersistenceUnit failed due to an error regarding @MappedSuperclass with Generic types.
Here is the main cause of the exception:
Caused by: java.lang.IndexOutOfBoundsException: Index: 8, Size: 8
at java.util.ArrayList.RangeCheck(ArrayList.java:547)
at java.util.ArrayList.get(ArrayList.java:322)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.resolveGenericTypes(MetadataAsmFactory.java:165)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.resolveGenericTypes(ClassAccessor.java:1611)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.discoverMappedSuperclassesAndInheritanceParents(EntityAccessor.java:282)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.preProcess(EntityAccessor.java:526)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage1(MetadataProject.java:1608)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:531)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:526)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1337)
I'm wondering if it's a bug? or my design isn't correct (The same design with same Test work fine with Hibernate !)
Here is the code I'm using:
@MappedSuperclass
public abstract class GenericEntity<PK> implements Serializable {
@MappedSuperclass
public abstract class SecondGenericEntity<PK> extends GenericEntity<PK> {
@Entity
@Table(name = "MY_ENTITY")
public class MyEntity extends SecondGenericEntity<Long> {
Re: @MappedSuperclass with Generic types [message #896728 is a reply to message #896422] Thu, 19 July 2012 09:59 Go to previous messageGo to next message
Bug 372092 was filed for what looks like the same issue, but a reproducable test case was not provided and it works in EclipseLink's tests. Please upload a test case to this bug or a new one.
Best Regards,
Chris
Re: @MappedSuperclass with Generic types [message #898764 is a reply to message #896422] Fri, 27 July 2012 09:36 Go to previous message
Here is a related test case (Attached "testcase-372092.zip") see also https://bugs.eclipse.org/bugs/show_bug.cgi?id=372092
[Updated on: Fri, 27 July 2012 09:36] by Moderator
Previous Topic:EclipseLink workbench: where is BLOB column type?
Next Topic:MOXy + Tomcat6 + Maven
Current Time: Sun Oct 19 09:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.03774 seconds
