Home » Language IDEs » C / C++ IDE (CDT) » Makefile does not run in Eclipse 2.1.2, CDT 1.2
Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89160] Fri, 12 December 2003 20:15 Go to next message
Originally posted by: gagraf.prodigy.net
Makefile is:
main.exe: main.obj
ilink32 main.obj
main.obj: main.cpp
bcc32 -c main.cpp
I use Borland BC++ in Win98. If I run make from the commamd line
(C:\Eclip\cpp\>make), main.exe is created and appears in the Eclipse
workspace and can be run inside Eclipse.
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89189 is a reply to message #89160] Sat, 13 December 2003 03:34 Go to previous messageGo to next message
George a. Graf wrote:
> Makefile is:
> main.exe: main.obj
> ilink32 main.obj
> main.obj: main.cpp
> bcc32 -c main.cpp
> (C:Eclipcpp>make), main.exe is created and appears in the Eclipse
Note original makefile does not work. This makefile works from command
line and still does not run from inside Eclipse:
main.exe: main.cpp
bcc32 main.cpp
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89204 is a reply to message #89189] Sat, 13 December 2003 09:32 Go to previous messageGo to next message
Originally posted by: Norbert.Marrek.siemens.com
Hi George,
> main.exe: main.cpp
> bcc32 main.cpp
Did you forget to put a TAB before the bcc32 line?
Bye,
Norbert
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89218 is a reply to message #89204] Sat, 13 December 2003 12:45 Go to previous messageGo to next message
Norbert Marrek wrote:
> Hi George,
> > main.exe: main.cpp
> > bcc32 main.cpp
> Bye,
> Norbert
Hi Norbert,
No. The tab got lost in the translation. I suspect my problem lies in the
support of non gnu make programs.
George
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89528 is a reply to message #89218] Mon, 15 December 2003 11:38 Go to previous messageGo to next message
> > Hi George,
> > > main.exe: main.cpp
> > > bcc32 main.cpp
> > Bye,
> > Norbert
> Hi Norbert,
Look at the C-Build view, what is the output ?
> George
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89621 is a reply to message #89528] Mon, 15 December 2003 13:43 Go to previous messageGo to next message
> > > Hi George,
> > > > main.exe: main.cpp
> > > > bcc32 main.cpp
> > > Bye,
> > > Norbert
> > Hi Norbert,
> > George
alain,
The C-Build view has:
make -k clean all
Remark: I suspect I need to do some configuring, but I don't find
documentation or examples.
George
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89706 is a reply to message #89621] Mon, 15 December 2003 17:53 Go to previous messageGo to next message
> > > George
> alain,
> make -k clean all
Is make in you path, i.e. when you start a cmd.exe
can you use make ?
I suprise that the output is just "make -k clean all"
usually you would have things like "Error -1 make.exe CreateProcess() ..."
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89735 is a reply to message #89706] Mon, 15 December 2003 22:18 Go to previous messageGo to next message
> > > > George
> > alain,
> > make -k clean all
> can you use make ?
Alain,
Not sure what "when you start a cmd.exe" means. But, when I start a DOS
window and change to the project directory, I can just enter "make" and
make runs and creates main.exe. (autoexec.bat contains PATH statement to
allow Borland's make program to run from and directory).
George
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #89987 is a reply to message #89735] Wed, 17 December 2003 12:27 Go to previous messageGo to next message
Hi George,
Rather than running "make" from the DOS window, try running "make -k clean
all"
(the same line you see in the C-Build view) and see what you get.
I suspect you should add to your Makefile:
clean :
<TAB> del main.exe
Also, the -k option may or may not be supported by Borland's make, I don't
know.
(It tries to keep building when part of the build fails, useful when
you have many files to compile.) You can remove it from the CDT build
command
by the project Properties > C/C++ Make Project > Make Builder > Build
Setting = Stop On Error.
Brent
"George a. Graf" <gagraf@prodigy.net> wrote in message
news:brlthm$633$1@eclipse.org...
> > > > > George
> > > alain,
> > > make -k clean all
> > can you use make ?
> Alain,
> George
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #90155 is a reply to message #89987] Thu, 18 December 2003 13:54 Go to previous messageGo to next message
Brent Nicolle wrote:
> Hi George,
> all"
> clean :
> <TAB> del main.exe
> know.
> command
> Cheers,
> Brent
Hi Brent,
Your comments made sense, but still have same problem: make does not run
inside Eclipse. I did the following:
1. changed makefile to:
all: main.exe
main.exe: main.cpp
<tab> bcc32 main.cpp
clean:
<tab> del main.exe
2. set Build Setting to Stop On Error.
Now, C-Build view shows: make clean all
And, in DOS window the command make clean all, first deletes main.exe and
then builds main.exe. In Eclipse, re-build project does not work.
Main.exe
can be run after I build it from the DOS window command line.
George
> > > > > > George
> > > > alain,
> > > > make -k clean all
> > > can you use make ?
> > Alain,
> > George
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #90169 is a reply to message #90155] Thu, 18 December 2003 14:07 Go to previous messageGo to next message
> inside Eclipse.
[snip]
> Main.exe
It sounds like you have the same problem as me. Same symptoms anyway. I too
am using Win98, I wonder if anyone ever tested CDT on 98 or just hoped it all
worked...
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #90318 is a reply to message #90169] Fri, 19 December 2003 10:56 Go to previous messageGo to next message
Ah.
To quote the favoured solution of a friend of mine:
1. Re-install your operating system.
Win98 is not a supported platform. After CDT 1.1, I remember trying it out
and being as disappointed as you are now.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36688
There are technical challenges to making Win98 work properly, and none
of the current contributors are interested in meeting those challenges.
At least now you know!
- Brent
"Gary" <eclipse@garydjones.mailshell.com> wrote in message
news:brsttk$vvq$1@eclipse.org...
> > inside Eclipse.
> [snip]
and
> > Main.exe
too
all
> worked...
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #90346 is a reply to message #90318] Fri, 19 December 2003 11:13 Go to previous messageGo to next message
> Ah.
Actually I think I'll just uninstall CDT, as going by what you say it can't
do what I need. Thanks for letting me know, I can free up the disk space for
something useful.
BTW, the original poster said in <brdp6v$1mu$1@eclipse.org> that he was
using W98. Seems a shame this knowledge isn't more readily available, for
example in the FAQ - "The CDT Framework is platform independent. It will
run where Eclipse will run". Yeah, right.
Re: Makefile does not run in Eclipse 2.1.2, CDT 1.2 [message #90526 is a reply to message #90346] Tue, 23 December 2003 09:07 Go to previous message
Good point about the FAQ, Gary.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49276
- Brent
news:brv83h$b91$1@eclipse.org...
> > Ah.
can't
for
> something useful.
Previous Topic:CDT for HP-Unix 11?
Next Topic:Tool bar,menu,wizard
Current Time: Wed Nov 05 04:07:03 EST 2025
Powered by FUDForum. Page generated in 0.05657 seconds
