Home » Language IDEs » Java Development Tools (JDT) » Ant View hangs from time to time
Ant View hangs from time to time [message #89553] Wed, 27 August 2003 08:14 Go to next message
Originally posted by: andreaundstefan.hoehn.com
We noticed that eclipse (probably due to the ant view) hangs pretty often
in version 2.1.1. Although I cannot really reproduce it (although it
happens around 5 to 10 times a day) it seems that it is heavily related
when you double click on a target in the ant view. Did anyone ever noticed
the same situation?
best regards
Stefan
Re: Ant View hangs from time to time [message #89614 is a reply to message #89553] Wed, 27 August 2003 11:06 Go to previous messageGo to next message
You are running out of memory.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24448
Darins
"Stefan Hoehn" <andreaundstefan@hoehn.com> wrote in message
news:bii7b5$bhi$1@eclipse.org...
> the same situation?
> best regards
> Stefan
Re: Ant View hangs from time to time [message #90781 is a reply to message #89614] Fri, 29 August 2003 09:54 Go to previous messageGo to next message
Thanks, Darin.
We downloaded the supplied fix (although some have called it a bit ugly)
and since then it seems to be much better.
BTW, I had looked through the buglist but didn't find this one.
Thanks again!
Stefan
Re: Ant View hangs from time to time [message #90796 is a reply to message #90781] Fri, 29 August 2003 10:23 Go to previous message
Stefan,
Are you able to try out Eclipse 3.0 and running Ant in a separate VM?
That's the best workaround...
Darins
news:binlv9$p8d$1@eclipse.org...
> Thanks, Darin.
> Thanks again!
> Stefan
Previous Topic:smart cursoring through java names doesn't work on prev-word
Next Topic:Trying remote debug against z/OS (USS)
Current Time: Sat Jul 26 12:43:14 EDT 2025
Powered by FUDForum. Page generated in 0.25868 seconds
