Home » Modeling » TMF (Xtext) » Access root instance of grammar of all resource files in the workspace
Access root instance of grammar of all resource files in the workspace [message #896120] Tue, 17 July 2012 06:28 Go to next message
Hey,
I would like to access the root element of my grammar. For instance:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "h_t_t_p_:_/_/_w_w_w.xtext.org/example/mydsl/MyDsl"
Model:
  greetings+=Greeting∗;
Greeting:
  'Hello' name=ID '!';
Is there a way I could access all Model instances (spread over several resources file in the workspace)? I need all Model instances in the generation process. Here is what I got so far:
If user saves one file, the generation process is triggered:
class MyDslGenerator implements IGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
		// HERE I CAN ACCESS THE PRESENT "Model" instance
I use following code to find the root element:
TreeIterator<EObject> it = resource.getAllContents();
while (it.hasNext()) {
	EObject next = it.next();
	if(next instanceof Model){
		//perform your operations!
		break;
With this solution I'm just able to find the Model instance of the current file (where the user hit save). How do I find all other? Thank you.
Kon
Re: Access root instance of grammar of all resource files in the workspace [message #896122 is a reply to message #896120] Tue, 17 July 2012 06:49 Go to previous messageGo to next message
Hi Kon!
Please read Xtend Generating from multiple input models for an approach.
~Karsten
Re: Access root instance of grammar of all resource files in the workspace [message #896157 is a reply to message #896122] Tue, 17 July 2012 08:41 Go to previous message
Thank you Karsten Smile
Previous Topic:Integrate existed interpreter with Xtext
Next Topic:Chain generation from language1 -> language2 -> java
Current Time: Fri Jul 18 20:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.04110 seconds
