Problem finalizing Model with stereotypes on association ends applied [message #896102] |
Tue, 17 July 2012 05:30  |
According to my question in the UML2 forum: http://www.eclipse.org/forums/index.php/t/367608/, I have done further debugging.
To give a briefly description of my problem. I use a profile with several stereotypes. The stereotypes should be applied to an OUT model which is UML2 (http://www.eclipse.org/uml2/3.0.0/UML). I apply a stereotype which is applicable to UML!Property to several properties. Most of them are association ends and some of them are attributes of classes.
I dispense with posting the code here, because it's in the mentioned UML2-forum-topic.
The application on attributes work fine. But if I add the properties to an association as navigableOwnedEnds when finalizing the model an IllegalArgumentException is thrown.
It appears only, if I apply my Property-stereotype to an UML!Property which is part of an association.
The full stack trace is the following.
org.eclipse.m2m.atl.engine.emfvm.VMException
at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:51)
at org.eclipse.m2m.atl.engine.emfvm.lib.ExecEnv.terminated(ExecEnv.java:2557)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:210)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:937)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1141)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor26.invoke(Unknown Source)
at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.applyDelayedInvocations(UML2ModelAdapter.java:136)
at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:49)
... 12 more
Caused by: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@a73925 (name: xsdElement, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
at org.eclipse.uml2.uml.internal.operations.ElementOperations.applyStereotype(ElementOperations.java:1413)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereotype(ElementImpl.java:510)
... 17 more
I've done some debugging. With the ATL debugger the applyStereotype-method is successfully called, but if it seems the atl script had run successful the IllegalArgumentException is thrown.
Does anyone have an idea? Is this an ATL-bug? I would be delighted if somebody has an idea what I could do.
Is there a way to directly debug the ATL engine?
Re: Problem finalizing Model with stereotypes on association ends applied [message #896117 is a reply to message #896102] |
Tue, 17 July 2012 06:06   |
Use the Java debugger; if necessary starting a nested Eclipse in debug
mode, but more easily by starting your main Eclipse with
-Xrunjdwp:server=y,transport=dt_socket,address=14143,suspend=n
so that you can then attach a second Eclipse as a debugger on the first.
Ed Willink
> debugging.
> classes.
> UML2-forum-topic.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 12 more
> (isActive: false)
> at
> at
> ... 17 more
Re: Problem finalizing Model with stereotypes on association ends applied [message #896345 is a reply to message #896282] |
Wed, 18 July 2012 03:01  |
The delayed application I also have identified, but not considered as very significant for the application.
Is it really necessary to apply the profile to every model element that should have a stereotype applied? Or have I understand your suggestion wrong? I thought the on the topmost model element containing all others the profile should be applied. Currently it works in this way.
One problem I have is that due to the delayed application of profile and stereotypes I could not read tagged values from the target model that I set in other rules.
FUDForum. Page generated in 0.25001 seconds
