Home » Modeling » EMF » creating a registry for objects with certain identifying features
creating a registry for objects with certain identifying features [message #895823] Mon, 16 July 2012 04:24 Go to next message
in our application, we want to prevent creating many "structurally equal" objects.
Let's say we have a class X with features a:A, b:B, c:C (A,B,C being classes or data types), then we don't want to have two X objects with the same values for a, b, and c. The reason here is to save memory and allow for a fast comparison of objects, using "==" instead of having to iterate over all the feature values.
How do we do that?
Our idea is to build a registry that basically consists of a (hash) map that maps lists of the identifying attributes to these objects, e.g. (A,B,C)->X.
The lists are basically a way to create a unique key.
Then, before creating a new X object, with a=a1, b=b1, c=c1 we would create a new list (a1, b1, c1) and see if an object of X with an equal list as key is already contained in the map.
Do you think that this is a good idea? Any other suggestions?
Does it make sense to use BasicEList.FastCompare lists for this purpose?
Thanks for your input
Joel
Re: creating a registry for objects with certain identifying features [message #895914 is a reply to message #895823] Mon, 16 July 2012 09:38 Go to previous messageGo to next message
Joel,
Comments below.
On 16/07/2012 10:24 AM, Joel Greenyer wrote:
> equal" objects.
I think it makes sense for data types that are immutable, but not so
much for classes.
> How do we do that?
> e.g. (A,B,C)->X.
If you do this for a data type, you can ensure that there is a static
utility method for creating instances and it can hide all this under the
covers.
For a class, the values can always be changed, and when deserializing,
the object is created first, and then the features are populated, so I
don't see how this approach can work for that.
Certainly for a data type if you can ensure that there is at most one
instance for any combination of values, you can rely on == instead of
equals.
> Joel
Re: creating a registry for objects with certain identifying features [message #895979 is a reply to message #895914] Mon, 16 July 2012 13:59 Go to previous messageGo to next message
Hi Ed,
thanks for your comments.
Yes, of course it only makes sense if what you are registering is not meant to be changed. Within our application we would ensure that.
Also, we would serialize and deserialize the objects in a plain list and after the deserialization we would re-initialize this registry map.
But would youhave any other suggestion than this key-list idea?
What we would really need is only a convenient way to calculate some unique hash-value for the registered objects.
Joel
On 16.07.2012 15:38, Ed Merks wrote:
> Joel,
> Comments below.
>> Hi,
> I think it makes sense for data types that are immutable, but not so much for classes.
>> How do we do that?
> If you do this for a data type, you can ensure that there is a static utility method for creating instances and it can hide all this under the covers.
> For a class, the values can always be changed, and when deserializing, the object is created first, and then the features are populated, so I don't see how this approach can work for that.
> Certainly for a data type if you can ensure that there is at most one instance for any combination of values, you can rely on == instead of equals.
>> Joel
Re: creating a registry for objects with certain identifying features [message #895986 is a reply to message #895979] Mon, 16 July 2012 14:16 Go to previous message
This sounds rather like what OCL has to do for Tuple types (and
Collection types) for which structurally equal types are the same type.
Computing the hash of the alphabetically sorted element names is
relatively cheap, so this is used as a hash to a list of types that may
have distinct element types for the same element names.
See
GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.pivot\src\org\eclipse\ocl\examples\pivot\manager\TupleTypeManager.java.
Ed Willink
On 16/07/2012 18:59, Joel Greenyer wrote:
> Hi Ed,
> Thanks
> Joel
>> Joel,
>> Comments below.
>>> Hi,
>>> equal" objects.
>> much for classes.
>>> How do we do that?
>>> e.g. (A,B,C)->X.
>> the covers.
>>> purpose?
>> equals.
>>> Joel
Previous Topic:[EMF Validation] how can i control multiple context?
Next Topic:[CDO 4.1] : Reattachment issue with EOpposite
Current Time: Sat Jul 26 18:58:54 EDT 2025
Powered by FUDForum. Page generated in 0.03356 seconds
