Juno: code errors in generated model code of static uml profile [message #892714] |
Fri, 29 June 2012 06:29  |
I'm porting a static profile from indigo to juno release.
I have already updated all changed extension points and references inside the uml profile. But when generating the model code from the genmodel, I experience a case error in the PackageImpl class (see below). It is easy to correct by hand and the profile works fine afterwards, but annoying as the error reappears every time the model code is generated again. Did I miss something while porting? Is there any way to fix this?
In the following snipped org.eclipse.uml2.types.typesPackage should actually be org.eclipse.uml2.types.TypesPackage. The line wasn't even there in indigo.
* Complete the initialization of the package and its meta-model. This
* method is guarded to have no affect on any invocation but its first.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public void initializePackageContents() {
if (isInitialized) return;
isInitialized = true;
// Initialize package
setName(eNAME);
setNsPrefix(eNS_PREFIX);
setNsURI(eNS_URI);
// Obtain other dependent packages
UMLPackage theUMLPackage = (UMLPackage)EPackage.Registry.INSTANCE.getEPackage(UMLPackage.eNS_URI);
org.eclipse.uml2.types.typesPackage thetypesPackage = (org.eclipse.uml2.types.typesPackage)EPackage.Registry.INSTANCE.getEPackage(org.eclipse.uml2.types.typesPackage.eNS_URI);
SystemViewPackage theSystemViewPackage = (SystemViewPackage)EPackage.Registry.INSTANCE.getEPackage(SystemViewPackage.eNS_URI);
Re: Juno: code errors in generated model code of static uml profile [message #895751 is a reply to message #892848] |
Sun, 15 July 2012 13:44   |
See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=382637.
Ed Willink
On 30/06/2012 13:41, Ed Willink wrote:
> Hi
> Are you specifying Types.genmodel as a used gen package? If so, this
> looks like a justification for reopening
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=366348.
> The intention is that the Types package is a hidden secret, so that
> users should not notice a UML2 3.0/4.0 change.
> Regards
> Ed Willink
> On 30/06/2012 12:22, Ed Merks wrote:
>> Christian,
>> I think this is a problem with the latest version of the
>> UML2.genmodel, which treats this types packages as kind of a built-in
>> model for which it produces a GenPackage wrapper automatically. I
>> suspect it's not initializing the GenPackage's prefix property
>> properly. Please open a bugzilla against UML2.
>>> meta-model. This
>>> first.
>>> * @generated
>>> setName(eNAME);
>>> setNsURI(eNS_URI);
FUDForum. Page generated in 0.03810 seconds
