Home » Newcomers » Newcomers » Colour Preferences
Colour Preferences [message #895682] |
Sat, 14 July 2012 17:23  |
Is there a way to export (then import) just the Java editor colour
preferences?
I have tried to edit the preferences export file, but the import states
that I cannot import partial settings.
Settings like:
/instance/org.eclipse.jdt.ui/semanticHighlighting.abstractMethodInvocation.bold=true
If there is no way to export/import, then what settings (in the
preferences file) do I need to make the importer import the colours?
Wojtek :-)
Re: Colour Preferences [message #895703 is a reply to message #895694] |
Sun, 15 July 2012 03:14   |
Ed Merks wrote :
> Wojtek,
> No, I don't think so, but you could copy your exported preference file and
> delete all the but the color settings from it so you end up with a
> preference file for just the colors.
Yes I tried doing that. I did a search for "semanticHighlighting" and
saved those. But the importer still complained about incomplete
settings.
So I either missed one or more, there are some which use a different
key, or there is some special flag which is required.
I really don't want to import the entire preferences as there are
skeletons from previous version and plugins I would like to go away.
Maybe kind of trivial, but I spent a lot of time tweaking the colours,
and my brain "sees" different syntax as required.
>> preferences?
>> Settings like:
>> If there is no way to export/import, then what settings (in the preferences
Wojtek :-)
Re: Colour Preferences [message #895713 is a reply to message #895703] |
Sun, 15 July 2012 04:46   |
Have you tried in a clean workspace to change a single setting to see
how exporting that looks?
On 15/07/2012 9:14 AM, Wojtek wrote:
> Ed Merks wrote :
>> Wojtek,
>> file and delete all the but the color settings from it so you end up
>> with a preference file for just the colors.
> saved those. But the importer still complained about incomplete settings.
>>> preferences?
>>> states that I cannot import partial settings.
>>> Settings like:
Re: Colour Preferences [message #895757 is a reply to message #895729] |
Sun, 15 July 2012 15:29   |
Toshihiro Izumi wrote :
> This works for example.(confirmed on 4.2.0)
>>/instance/org.eclipse.jdt.ui/semanticHighlighting.staticField.italic=false
>>file_export_version=3.0
Here is the entire file I am trying to use as an import. I added the
file version at the end, but it still does not import.
#Sun Jul 15 03:01:14 PDT 2012
/instance/org.eclipse.jdt.ui/pf_coloring_argument=0,0,255
/instance/org.eclipse.jdt.ui/pf_coloring_assignment_bold=true
/instance/org.eclipse.jdt.ui/pf_coloring_assignment=255,0,0
/instance/org.eclipse.jdt.ui/pf_coloring_comment=128,128,128
/instance/org.eclipse.jdt.ui/pf_coloring_key=128,0,0
/instance/org.eclipse.jdt.ui/pf_coloring_value=0,0,0
/instance/org.eclipse.jdt.ui/semanticHighlighting.abstractMethodInvocation.color=0,0,160
/instance/org.eclipse.jdt.ui/semanticHighlighting.abstractMethodInvocation.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.abstractMethodInvocation.underline=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.annotation.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.annotation.color=255,128,0
/instance/org.eclipse.jdt.ui/semanticHighlighting.annotationElementReference.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.autoboxing.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.autoboxing.color=255,0,0
/instance/org.eclipse.jdt.ui/semanticHighlighting.autoboxing.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.autoboxing.strikethrough=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.autoboxing.underline=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.class.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.class.color=128,0,64
/instance/org.eclipse.jdt.ui/semanticHighlighting.class.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.enum.color=128,0,255
/instance/org.eclipse.jdt.ui/semanticHighlighting.enum.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.inheritedMethodInvocation.color=0,0,128
/instance/org.eclipse.jdt.ui/semanticHighlighting.inheritedMethodInvocation.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.inheritedMethodInvocation.underline=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.interface.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.interface.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.localVariable.color=0,128,128
/instance/org.eclipse.jdt.ui/semanticHighlighting.localVariable.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.localVariableDeclaration.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.localVariableDeclaration.color=0,128,128
/instance/org.eclipse.jdt.ui/semanticHighlighting.localVariableDeclaration.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.method.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.methodDeclarationName.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.parameterVariable.color=128,0,0
/instance/org.eclipse.jdt.ui/semanticHighlighting.parameterVariable.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.staticFinalField.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.staticFinalField.color=0,0,255
/instance/org.eclipse.jdt.ui/semanticHighlighting.staticFinalField.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.staticFinalField.italic=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.staticMethodInvocation.color=0,128,255
/instance/org.eclipse.jdt.ui/semanticHighlighting.typeArgument.bold=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.typeArgument.enabled=true
/instance/org.eclipse.jdt.ui/semanticHighlighting.typeParameter.enabled=true
/instance/org.eclipse.jdt.ui/sourceHoverBackgroundColor=255,255,225
/instance/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=250,255,250
/instance/org.eclipse.ui.editors/currentLineColor=253,253,253
/instance/org.eclipse.ui.editors/errorIndicationColor=255,0,0
/instance/org.eclipse.ui.editors/infoIndicationColor=0,255,0
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/instance/org.eclipse.ui.editors/occurrenceIndicationColor=255,255,0
/instance/org.eclipse.ui.editors/occurrenceIndicationInVerticalRuler=true
/instance/org.eclipse.ui.editors/warningIndicationColor=255,128,0
Wojtek :-)
Re: Colour Preferences [message #895788 is a reply to message #895785] |
Mon, 16 July 2012 00:08  |
> Your file can be imported. It works for me :)
> (confirmed on eclipse for some of syntax coloring settings and matched
> against re-exported preferences)(with new installation)
> I wouldn't say you did nothing.
I must have missed some settings in the "clean" file. You are right it
does import, but the changes I was looking for did not appear.
Wojtek :-)
Current Time: Wed Jul 23 04:15:16 EDT 2025
Powered by FUDForum. Page generated in 0.17027 seconds
