Home » Eclipse Projects » Mylyn » embedding Mylyn WikiText MarkupViewer
embedding Mylyn WikiText MarkupViewer [message #889961] Wed, 20 June 2012 08:12 Go to next message
I went through the Mylyn Wiki Text Developer guide, but unable to achieve the following:
I want to embed Markup Viewer with Content Assist & Cheat Sheets with editing enabled for Textile Language in one our views extending ViewPart.
We are using the following code but we are seeing nothing more than a text editor
     public void createPartControl(Composite parent) {
              markupViewer  = new MarkupViewer(parent, null, SWT.BORDER | SWT.WRAP | SWT.V_SCROLL);
              markupViewer.setMarkupLanguage(new TextileLanguage());
              MarkupViewerConfiguration configuration = new MarkupViewerConfiguration(markupViewer);
              markupViewer.configure(configuration);
        markupViewer.getTextWidget().setEditable(true);
Please advise how can I achieve this.
Best Regards,
Tarun
[Updated on: Wed, 20 June 2012 08:15] by Moderator
Re: MarkupViewer [message #895581 is a reply to message #889961] Fri, 13 July 2012 12:51 Go to previous message
Tarun,
Your code sample looks good, and is following the example from the
developer guide[1]. There is a very simple test application in the
tests bundle that you can use as an example:
org.eclipse.mylyn.wikitext.textile.core.Main
You should be getting a text editor that is configured for wiki editing
(you should get content-assist, wiki formatting etc.) What were you
expecting? Please file a bug if you think that something is not working
properly.
David
[1]
http://help.eclipse.org/juno/topic/org.eclipse.mylyn.wikitext.help.ui/help/devguide/WikiText-and-the-UI.html?cp=31_3_2
On 6/20/2012 5:12 AM, Tarun Telang wrote:
> * Embedding a Markup Viewer with Content Assist & Cheat Sheet with
> text editor
> Please advise how do we achieve this.
> Best Regards,
> Tarun
Previous Topic:"Failed to download project list: Premature end of file" error while creating a new JIRA Q
Next Topic:Generating toc in pdf via WikiText and xslfo and fop
Current Time: Sun Jul 20 21:14:51 EDT 2025
Powered by FUDForum. Page generated in 0.06894 seconds
