Problem with eSetResource(null, null) in EMF from GMF in Eclipse Juno [message #895518] |
Fri, 13 July 2012 07:17  |
Hi People,
we installed the new Eclipse 4.2 and we are currently facing the following problem in EMF/GMF code.
In the class (GMF) there is the following method.
public static EObject appendEObjectAt(EObject eObject,
EReference reference, EObject referencedObject) {
if (isOkToAppendEObjectAt(eObject, reference, referencedObject) == false) {
return null;
if (reference.isContainment()) {
((InternalEObject)referencedObject).eSetResource(null,null);
sendCreateEvent(referencedObject);
((Collection) eObject.eGet(reference)).add(referencedObject);
return referencedObject;
which calls
The implementation of has changed in EMF from the previous version, ... in BasicEObjectImpl now there is the following new implementation
public NotificationChain eSetResource(Resource.Internal resource, NotificationChain notifications)
Resource.Internal oldResource = eDirectResource();
// When setting the resource to null we assume that detach has already been called in the resource implementation
if (oldResource != null && resource != null)
notifications = ((InternalEList<?>)oldResource.getContents()).basicRemove(this, notifications);
oldResource.detached(this);
which was before (Eclipse Indigo)
if (oldResource != null)
if (resource != null)
As a consequence, the behavior is different for a call and the object is not removed from the resource with as it previously was.
Please, let us know if the behavior is correct or if the implementation is wrong either in GMF or EMF. Do we have to modify something in our source code to continue using the Clipboard support of GMF as previously?
Many thanks
Tiziano
Re: Problem with eSetResource(null, null) in EMF from GMF in Eclipse Juno [message #895526 is a reply to message #895518] |
Fri, 13 July 2012 07:38  |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Tiziano,<br>
<br>
This change was made to fix <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=346805">https://bugs.eclipse.org/bugs/show_bug.cgi?id=346805</a>.
<br>
<br>
This API was never intended to be called directly by clients:<small><br>
</small>
<blockquote><small> /**</small><br>
<small> * Sets this object to be directly contained by the
resource </small><br>
<small> * and returns accumulated notifications.</small><br>
<small> * This is only done as the inverse of {@link
Resource#getContents()}<code>.add(this)</code>.</small><br>
<small> * @return accumulated notifications.</small><br>
<small> */</small><br>
<small> NotificationChain eSetResource(Resource.Internal
resource, NotificationChain notifications);</small><br>
</blockquote>
The GMF code should be using resource.getContents().remove(...).
I.e., perhaps it should be
referencedObject.eResource().getContents().remove(referencedObject)
though I'm not sure if the referenced object is necessarily
contained directly in a resource so maybe it should check that
eResource() isn't null. <br>
<br>
You should open a bugzilla for the GMF runtime to fix this.<br>
<br>
<br>
<br>
<div class="moz-cite-prefix">On 13/07/2012 1:17 PM, Tiziano Leidi
wrote:<br>
</div>
<blockquote cite="mid:jtp04f$js0$1@xxxxxxxxe.org" type="cite">Hi
People,
<br>
<br>
<br>
In the class ClipboardSupportUtil (GMF) there is the following
method.
<br>
<br>
<br>
<br>
<br>
return null;
<br>
<br>
<br>
<br>
<br>
<br>
((Collection)
<br>
<br>
<br>
<br>
which calls eSetResource(null,null)
<br>
<br>
The implementation of eSetResource has changed in EMF from the
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
notifications =
notifications);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
notifications =
notifications);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
eSetResource(null,null) and the object is not removed from the
resource with basicRemove as it previously was.
<br>
<br>
<br>
<br>
Many thanks
<br>
Tiziano
<br>
<br>
<br>
</blockquote>
<br>
<br>
</body>
</html>
FUDForum. Page generated in 0.24117 seconds
