Home » Archived » BIRT » Editable Chart in BIRT doc file(Not able to edit chart in BIRT doc file)
Editable Chart in BIRT doc file [message #895330] Thu, 12 July 2012 09:11 Go to next message
Dear All,
I have a requirement where I need to edit the BIRT graph (chart) when exported to doc file (MS Word). The problem is that the chart successfully loads in my doc file but comes up as a non-editable image. I dont find a way to dynamically change the numbers in this chart. Although I can change the data in the corresponding table of this chart which is underneath. You can refer the file as attached.
Request you to please suggest a way to achieve a solution to my problem. I would really appreciate your help if you can attach an example also.
Nitin
  • Attachment: Metrics.docx
    (Size: 104.25KB, Downloaded 257 times)
Re: Editable Chart in BIRT doc file [message #895404 is a reply to message #895330] Thu, 12 July 2012 13:26 Go to previous messageGo to next message
Nitin,
This is not supported in the current release of BIRT.
Jason
On 7/12/12 9:11 AM, Nitin Sharma wrote:
> Dear All,
> Nitin
Re: Editable Chart in BIRT doc file [message #895477 is a reply to message #895404] Fri, 13 July 2012 04:40 Go to previous messageGo to next message
Thanks for replying Jason. Any idea by which BIRT release this issue would be addressed? Also is there a workaround to address my problem?
Nitin
Re: Editable Chart in BIRT doc file [message #896032 is a reply to message #895477] Mon, 16 July 2012 22:33 Go to previous messageGo to next message
The emitters I know of that do something with the chart currently do not
emit editable charts, just images.
Jason
> Nitin
Re: Editable Chart in BIRT doc file [message #896033 is a reply to message #896032] Mon, 16 July 2012 22:34 Go to previous messageGo to next message
BTW you may want to open a bugzilla request for this.
Jason
> Jason
>> Thanks,
>> Nitin
Re: Editable Chart in BIRT doc file [message #896137 is a reply to message #896033] Tue, 17 July 2012 07:58 Go to previous message
Thanks for the reply Jason!! Really appreciate.
Previous Topic:Extending the BIRT viewer?
Next Topic:BIRT 4.2 Default Value for Dataset Input parameter is not working
Current Time: Sun Jul 27 16:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.03535 seconds
