Home » Eclipse Projects » Eclipse 4 » 'simple' has been deprecated: renamed as swt-simple
'simple' has been deprecated: renamed as swt-simple [message #895340] Thu, 12 July 2012 09:55 Go to next message
I see this message in the log...
!MESSAGE CSS property 'simple' has been deprecated: renamed as swt-simple
Will swt-simple work with old versions of eclipse or only 4.2?
I tried to search for some documentation on swt-simple but haven't come up with much to determine when it was introduced.
Re: 'simple' has been deprecated: renamed as swt-simple [message #895362 is a reply to message #895340] Thu, 12 July 2012 11:00 Go to previous messageGo to next message
Yes, swt-simple works with 4.2. What older versions of eclipse do you mean? 4.1?
CSS doesn't drive styling in the eclipse 3.x stream.
PW
Re: 'simple' has been deprecated: renamed as swt-simple [message #895372 is a reply to message #895362] Thu, 12 July 2012 11:20 Go to previous messageGo to next message
Specifically 4.1, 3.7, 3.6?
Sounds like to me from you comment that
swt-simple will work with 4.2 and 4.1
But not 3.6
Re: 'simple' has been deprecated: renamed as swt-simple [message #895897 is a reply to message #895372] Mon, 16 July 2012 09:03 Go to previous message
swt-simple works in 4.2. simple works in 4.1 and 4.2 but generates a warning in 4.2. But Indigo is based on 3.7 and AFAIK no one is using 4.1.
Neither keywords work in 3.x, as 3.x doesn't ship the SWT CSS engine.
PW
Previous Topic:Removing/adding context menu entries based on current selection
Next Topic:start application window from osgi console
Current Time: Sat Jul 26 19:21:19 EDT 2025
Powered by FUDForum. Page generated in 0.03945 seconds
