Home » Modeling » EMF » My Model is getting to big...(My Model is getting to big...)
My Model is getting to big... [message #894735] Tue, 10 July 2012 06:17 Go to next message
Hi 2 all,
I have the Problem that I have a business model which needs more than 1GB main memory.
I have an import function which I use to load data from a server. The incoming data is mapped so new EObjects that are added to the model...the model in memory grows and grows and when I reach the one GB my system is breaking.
How can I master this ? Is CDO an option ? Is it much work to use CDO (only for minimizing the model memory) or is it simply already done by doing this:
http://wiki.eclipse.org/CDO/Preparing_EMF_Models
Thanks for help
Re: My Model is getting to big... [message #894741 is a reply to message #894735] Tue, 10 July 2012 06:29 Go to previous messageGo to next message
Markus,
Comments below.
On 10/07/2012 12:17 PM, Markus Jo wrote:
> Hi 2 all,
> 1GB main memory.
That's a big business. :-P
You can increase the heap. A 64 bit VM can have a very large heap.
Yes, I think CDO can help with that.
That just helps generate a nicely CDO enable model. You'll still need to
learn about CDO transactions to manage resources that are stored in a
repository.
> Thanks for help
Re: My Model is getting to big... [message #894742 is a reply to message #894741] Tue, 10 July 2012 06:45 Go to previous messageGo to next message
Thx for the fast answer.
The 64VM is no choice.... our customers expect a version for 32bit.
The Project is already in the second half and we are only allowed to make use of 1GB main memory. Would be no Problem with the inital demand....there we have 600mb data. But now we should be able to display two years (instead of one) of data and that´s to much.
The CDO approach seems to need to much time. Is there a solution just for solving the "big model in main memory" problem that we can 'easily' do by hand? Splitting to many model model files ? There is the "Control.." Action in the Editors TreeView Context Menu where you can set an own model file for some parts of the model. But this seems to be done by the client-user. Is there a way to do this automatically without reimplementing EMF ? Something like:
- Outsorcing every Object of type XY to an own ressource
- Unload it when possible
- Load it when needed
- Deleting the resource file when deleting the object in the client.
Its very hard to find the entry points for this in the EMF code.
Re: My Model is getting to big... [message #894795 is a reply to message #894742] Tue, 10 July 2012 10:36 Go to previous messageGo to next message
Comments below.
You mean it performs poorly?
> files ?
Yes, you can split objects across resources.
All that does it create a resource and put the object in that resource;
of course you can do that programmatically (resourceSet.createResource
and resource.getContents().add(eObject).
Unloading doesn't free up the memory if there are other references to
the objects in the resource.
ResourceSet and Resource are your friends. They're not such big APIs.
Re: My Model is getting to big... [message #894807 is a reply to message #894795] Tue, 10 July 2012 11:15 Go to previous messageGo to next message
Maybe a dumb question you already using MinimalEObject? It will at least
save some bits ;-)
Tom
Am 10.07.12 16:36, schrieb Ed Merks:
> Comments below.
>> files ?
Re: My Model is getting to big... [message #894927 is a reply to message #894807] Wed, 11 July 2012 02:29 Go to previous messageGo to next message
@Ed
No, I didnt mean JDO performs poorly.... I brain performs that poorly that I think I would need to much project time to be able to use CDO properly. But thanks for your hints. I am currenty trying to swap some Elements to other resources when the doSave(..) method of the MetamodelEditor is triggered.
One question to that....If I move an Object to antoher ressource and save this resource before saving the "main"-resource, do I have to remove the moved object from the resource or does EMF do this for me ?
@Thomas
Hi, I found a presentation of that but there were just one or two lines about that and I did not found an implementation of MinimalEObject yet. Do you have the class ? How do I activate it ? By specifying its path in the genmodel under "Root Extends Class/Interface" ?
Re: My Model is getting to big... [message #894935 is a reply to message #894927] Wed, 11 July 2012 03:46 Go to previous messageGo to next message
@Ed
My question is answered....it removes the swapped elements automatically.
@All
But....the little memory window at the lower right of my Application still shows the same high value (after clicking some times on the garbage collector icon). I swapped nearly half size of the main model file to little fragments whichs contents are not displayed/expanded in the clients tree view. So I thought they would not be loaded....not before I expand the model tree in the client to theirs levels. Do I have to activate some kind of lazy loading ? Or is it propable that there is some kind of initilaization in the background that causes loading all fragement model files to the main memory ?
Re: My Model is getting to big... [message #894940 is a reply to message #894935] Wed, 11 July 2012 03:52 Go to previous messageGo to next message
Am 11.07.2012 09:46, schrieb Markus Jo:
> @Ed
> @All
You may find my article http://thegordian.blogspot.de/2008/11/how-scalable-are-my-models.html interesting as it kind of
explains what's going on on your heap ;-)
Cheers
/Eike
http://www.esc-net.de
Re: My Model is getting to big... [message #894942 is a reply to message #894927] Wed, 11 July 2012 03:58 Go to previous messageGo to next message
Am 11.07.2012 08:29, schrieb Markus Jo:
> @Ed
I guess you mean CDO. From my experiences with CDO adopters I have the impression that many, if not most, of them have
managed the common scenarios in less than a day. Free and prompt support is given here. Please note that we may also be
able to support you in a more exclusive, commercial fashion: http://www.eclipse.org/cdo/support
Cheers
/Eike
Re: My Model is getting to big... [message #894945 is a reply to message #894935] Wed, 11 July 2012 04:21 Go to previous messageGo to next message
Markus,
Proxies are resolved on demand. You can monitor the contents of the
resource set, perhaps setting a breakproint in
ResourceSetImpl.demandLoad to see what in your application is causing
proxies to be resolved.
On 11/07/2012 9:46 AM, Markus Jo wrote:
> @Ed
> @All
Re: My Model is getting to big... [message #895239 is a reply to message #894945] Thu, 12 July 2012 04:43 Go to previous messageGo to next message
Hi Ed,
done it.....the resources were loaded when we add some Listener or ContentAdapters to our model...something like this:
EContentAdapter eContentAdapter = new ModelNotificationListener();
eContentAdapter.setTarget(modelRoot);
or like
editingDomain.getResourceSet().eAdapters().add(AccessControl.getInstance());
Then the whole model gets traversed and alle resources were loaded. Any Idea how we can prevent this ? Are there listeners or flag so set which only register on loaded resources and reregister when a resource is loaded later ?
Re: My Model is getting to big... [message #895240 is a reply to message #895239] Thu, 12 July 2012 04:47 Go to previous messageGo to next message
Antoher question....unloading after the notifier are registered/added does not help the garbage collector, right ? Because the Notifier and ContentAdapters hold references to the model objects ?
Re: My Model is getting to big... [message #895318 is a reply to message #895239] Thu, 12 July 2012 08:46 Go to previous messageGo to next message
Markus,
You can specialize the EContentAdapter's resolve method to return
false. Then it will start listening to after the proxy is resolved.
On 12/07/2012 10:43 AM, Markus Jo wrote:
> Hi Ed,
> or like
> is loaded later ?
Re: My Model is getting to big... [message #895319 is a reply to message #895240] Thu, 12 July 2012 08:47 Go to previous message
Markus,
Unloading clears the eAdapters list of all the unloaded EObjects.
Previous Topic:Fits CDO to my needs?
Next Topic:How to implement Tool tip for tree items
Current Time: Sun Aug 31 07:19:54 EDT 2025
Powered by FUDForum. Page generated in 0.13814 seconds
