Order if content assist items [message #895061] |
Wed, 11 July 2012 10:57  |
I have moved my XText application to Eclipse 4.2 and XText 2.3 and have the following problem:
I named all my templates starting with - (e.g. -Script), and in the CA list they used to come on top of the list; now they come at the bottom.
Can somebody explain it to me, and even better tell me how to revert it ?
MS
Re: Order if content assist items [message #895308 is a reply to message #895299] |
Thu, 12 July 2012 08:24   |
Michel,
did you try to return a relevance that is higher than the relevance of
the other proposals, eg. 10k ?
Sebastian
Am 12.07.12 14:00, schrieb Michel Simeon:
> Thanks for the comment, but I am not sure what to do with it.
> I looked into
> org.eclipse.xtext.ui.editor.templates.DefaultTemplateProposalProvider.getRelevance(Template)
> and what I found is:
> public int getRelevance(Template template) {
> return 90;
> I guess I could overwrite this method in order to change the relative
> order of templates, but my problem is different: pressing Ctrl-Space
> produces a list of proposals that in my case would generally include a
> mix of IDs, keywords and template names. By naming all my templates
> starting with - (e.g. -Script), they are automatically grouped together,
> and in the CA list of the previous version of my DSL they used to come
> on top of the list, which is what I wanted. In other words, -Axx or -Zxx
> came before Axx.
> But now the group comes at the bottom, and i do not know how to change
> the overall sorting order of the content-assist list.
> Any other suggestions would be most welcome.
> MS
Re: Order of content assist items [message #895427 is a reply to message #895382] |
Thu, 12 July 2012 16:57   |
Thanks again.
It does work indeed, now all the templates come on top of the CA proposals list. For those interested, this is what I did, based on the suggestions I received:
My language being called Mads, I defined:
public class MadsTemplateProposalProvider extends DefaultTemplateProposalProvider{
@Inject
public MadsTemplateProposalProvider(TemplateStore templateStore,
ContextTypeRegistry registry, ContextTypeIdHelper helper) {
super(templateStore, registry, helper);
public int getRelevance(Template template){
return 10000;
and then I added the following to my MadsUiModule :
public Class<? extends DefaultTemplateProposalProvider>
bindDefaultTemplateProposalProvider(){
return MadsTemplateProposalProvider.class;
MS
P.S. Even if that works, I still would like to understand why things have changed
when moving from Indigo to Juno !!!
Re: Order of content assist items - CA test [message #897272 is a reply to message #895474] |
Mon, 23 July 2012 09:24  |
HI Michel,
did you have any simple example on how to write and apply a template proposal, i want to write some template such that during content assist ( crtl+space) i have the different proposition written by me .
The problem is i don't know where to start.
i will be very gratefull if you can show to me how to do it step by step.
Thks and Best regards,
Frank
FUDForum. Page generated in 0.05986 seconds
