Home » Language IDEs » PHP Development Tools (PDT) » [Q] Build Path - difference between Use as a source and Include
[Q] Build Path - difference between Use as a source and Include [message #894426] Mon, 09 July 2012 04:09 Go to next message
what is the difference between this two menu items in PHP Explorer Context Menu?
On the picture in attachment is location of the menu items.
Thank you
Re: [Q] Build Path - difference between Use as a source and Include [message #894646 is a reply to message #894426] Mon, 09 July 2012 20:02 Go to previous messageGo to next message
Hi sNop,
I'm not sure what's the question since you're not a newbie...
PHP Project has a source folder to build. It is same as the project folder by default and it can be customized at Preferences > PHP > New Project Layout.
'Use as Source Folder' changes it on the fly.(this action adjusts inclusion/exclusion pattern also)
'Include' simply adds selected folder to build path.
'Exclude' simply removes selected folder from build path.
Include/Exclude are convenient actions for modifying build path(inclusion/exclusion pattern). See Configure Build Path(or Project Properties) > PHP Build Path.
This is a feature of DLTK and it had been introduced in pdt 2.0.
Best regards
Re: [Q] Build Path - difference between Use as a source and Include [message #895183 is a reply to message #894646] Wed, 11 July 2012 18:05 Go to previous messageGo to next message
i think sNop meant the 2 menu entries in the top-level right click menu: "Build Path" and "Include Path" and what the difference between these 2 paths is. this stackoverflow answer sums it up quite nicely.
[Updated on: Wed, 11 July 2012 18:05] by Moderator
Re: [Q] Build Path - difference between Use as a source and Include [message #895196 is a reply to message #895183] Wed, 11 July 2012 20:23 Go to previous messageGo to next message
Oh, I didn't guess so because of buildpath2.jpg Cool
Re: [Q] Build Path - difference between Use as a source and Include [message #895270 is a reply to message #895183] Thu, 12 July 2012 06:29 Go to previous messageGo to next message
I don't think this, Thosi wrote right answer.
> http://stackoverflow.com/questions/981956/whats-the-difference-between-the-build-path-and-the-include-path-in-eclipse-pdt sums it up quite nicely.
Re: [Q] Build Path - difference between Use as a source and Include [message #895273 is a reply to message #894646] Thu, 12 July 2012 06:33 Go to previous message
On 10. 7. 2012 2:02, Toshihiro Izumi wrote:
> Hi sNop,
sry, I didn't study the difference, I simply ask here :), was lazy
Exactly what i want to know, thank you
The menu item 'Use as Source Folder' confused me, I absolutely understand how build path works.
> Best regards
Previous Topic:Regression in Juno? Dragging source files between Windows
Next Topic:External Tools
Current Time: Fri Nov 07 22:57:48 EST 2025
Powered by FUDForum. Page generated in 0.03839 seconds
