Home » Archived » BIRT » Re: Setting Persistent Global Variable from DataSet
Re: Setting Persistent Global Variable from DataSet [message #874874] Mon, 21 May 2012 13:45 Go to next message
Reference the value using dataSetRow syntax. Take a look at the
attached example.
Jason
On 5/19/2012 4:35 AM, TO C wrote:
> I'm trying to set a Persistent Global Variable from the column of a
> dataset.
> I've tried using OnFetch as below:
> var myvar = this.getDataRowData().getColumnValue("Variable");
> reportContext.setPersistentGlbalVariable("VariableData", myvar.toString());
> This isn't working though.
> I want a Persistent Global Variable set to the Value of the column
> Variable (it'll be the same across the dataset).
> Any ideas?
Re: Setting Persistent Global Variable from DataSet [message #895142 is a reply to message #874874] Wed, 11 July 2012 15:32 Go to previous messageGo to next message
Thanks for this example. Can you show me how to set a Persistent Global Variable from an aggregate of a dataset.
Re: Setting Persistent Global Variable from DataSet [message #895160 is a reply to message #895142] Wed, 11 July 2012 16:41 Go to previous messageGo to next message
See attached example
Re: Setting Persistent Global Variable from DataSet [message #895161 is a reply to message #895142] Wed, 11 July 2012 16:41 Go to previous messageGo to next message
Re: Setting Persistent Global Variable from DataSet [message #895162 is a reply to message #895142] Wed, 11 July 2012 16:41 Go to previous messageGo to next message
Re: Setting Persistent Global Variable from DataSet [message #895164 is a reply to message #895142] Wed, 11 July 2012 16:41 Go to previous messageGo to next message
Re: Setting Persistent Global Variable from DataSet [message #895557 is a reply to message #895164] Fri, 13 July 2012 10:17 Go to previous message
Thanks for your help Jason.
I am getting the aggregates into the main report. But I'm getting the totals from the previous work order each time, not the current work order.
[Updated on: Fri, 13 July 2012 12:06] by Moderator
Previous Topic:How to get chart legend value as an input in parameter of target report
Next Topic:Stored Procedure
Current Time: Wed Jul 23 12:23:13 EDT 2025
Powered by FUDForum. Page generated in 0.34949 seconds
