Home » Archived » BIRT » Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site(Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site)
Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site [message #894877] Tue, 10 July 2012 17:21 Go to next message
We are trying to render BIRT Charts to our RCP Application on Expeditor and Need to Install BIRT Chart Framework 3.7.0 and Dependant Features (See Attachment).
Now this works fine from the BIRT Update Site that I downloaded as part of the BIRT All In one 3.7. Now the issue with this approach is
1) There are common plugins installed as part of the dependancies that our Expeditor Installation already has and this might conflict with other applications.
For this reason we tried to create our own update siteby modifying the feature.xml to exclude common plufins but when trying to install the features this way it gives a SignatureException and that is because the BIRT Plugins are Signed. see attachment
Is there any way BIRT/Eclipse can provide Unsigned Version of the BIRT Plugins so we can create a Custom Update site based on our requirements.
Vinay
  • Attachment: Expeditor.JPG
    (Size: 119.41KB, Downloaded 180 times)
  • Attachment: error.JPG
    (Size: 45.21KB, Downloaded 171 times)
Re: Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site [message #895121 is a reply to message #894877] Wed, 11 July 2012 14:13 Go to previous messageGo to next message
Vinay
Can you open a bugzilla request for this feature.
Jason
On 7/10/12 5:21 PM, Vinay Kumar wrote:
> Vinay
Re: Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site [message #895133 is a reply to message #895121] Wed, 11 July 2012 14:43 Go to previous messageGo to next message
Hi Jason,
Thanks for the lead. I have created a bug for the issue in Eclipse Bugzilla.
Bug 384863 - Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site (edit)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=384863
Cheers!
Vinay
[Updated on: Wed, 11 July 2012 14:43] by Moderator
Re: Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site [message #895134 is a reply to message #895121] Wed, 11 July 2012 14:44 Go to previous message
Hi Jason,
Cheers!
Vinay
Previous Topic:Remove BIRT database connection
Next Topic:which event occurs when we close the report in report viewer ??
Current Time: Sun Jul 27 08:15:43 EDT 2025
Powered by FUDForum. Page generated in 0.03428 seconds
