Home » Eclipse Projects » EclipseLink » Problem in using SQL Keyword in JPQL(ORDER BY and SQL are not separated by a comma)
Problem in using SQL Keyword in JPQL [message #894815] Tue, 10 July 2012 11:59 Go to next message
I try to use the following Named Query;
@NamedQuery (name="findbyNr",
query="SELECT o FROM MyBean o WHERE o.Nr= :Nr ORDER BY o.year DESC SQL('FETCH FIRST 100 ROWS ONLY')"
When I test my code I get the following exception:
Exception Description: Syntax error parsing [SELECT o FROM MyBean o WHERE o.Nr = :Nr AND ORDER BY o.year DESC SQL('FETCH FIRST 100 ROWS ONLY')].
[java] [124, 125] The ORDER BY clause has 'o.year DESC ' and 'SQL('FETCH FIRST 100 ROWS ONLY')' that are not separated by a comma.
[java] at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.createDeployFailedPersistenceException(EntityManagerSetupImpl.java:616)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:596)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:186)
If I place a comma between DESC and SQL, so my DB2 driver complains like:
16:58:40 [SELECT - 0 row(s), 0.000 secs] [Error Code: -104, SQL State: 42601] DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=FIRST;;ASC DESC, DRIVER=3.57.82
So how can I solve my problem? Or is it a bug?
Any input welcome.
best regards,
Igor
Re: Problem in using SQL Keyword in JPQL [message #895097 is a reply to message #894815] Wed, 11 July 2012 12:43 Go to previous messageGo to next message
SQL is not a key word in JPQL - there is no way to use plain SQL within a JPQL query. You either must use a nativeQuery and pass in the full SQL string you want to execute, or rely on non-JPA specific provider functionality to append your SQL to the JPQL query.
In EclipseLink you might do that by getting the SQL generated for the JPQL query, append to it. Getting the SQL is described here:
http://wiki.eclipse.org/EclipseLink/FAQ/JPA#How_to_get_the_SQL_for_a_Query.3F
and an example here using the underlying native EclipseLink query (TopLink in this case, but its the same api):
https://forums.oracle.com/forums/thread.jspa?threadID=308895
Best Regards,
Chris
Re: Problem in using SQL Keyword in JPQL [message #895099 is a reply to message #895097] Wed, 11 July 2012 12:58 Go to previous messageGo to next message
You could use the query hint "eclipselink.sql.hint" to specify database hints, but these are added immediately after the SELECT in the SQL - you can file an enhancement to get them printed at the end of the SQL for the DB2 platform if that is required.
Re: Problem in using SQL Keyword in JPQL [message #895124 is a reply to message #895099] Wed, 11 July 2012 14:20 Go to previous messageGo to next message
I missed that the SQL key word was added to EclipseLink 2.4:
http://wiki.eclipse.org/EclipseLink/DesignDocs/312146
It is treated though like a function in JPQL processing and native EclipseLink expressions support. Please file a bug to have it excluded from validation and directly added to the generated SQL. My prior posts detail alternate solutions.
Best Regards
Chris
Re: Problem in using SQL Keyword in JPQL [message #899629 is a reply to message #895124] Wed, 01 August 2012 11:53 Go to previous messageGo to next message
The SQL operator can only be used inside an existing clause in JPQL, it cannot define its own clause.
Try,
SELECT o FROM MyBean o WHERE o.Nr= :Nr ORDER BY SQL('? DESC FETCH FIRST 100 ROWS ONLY', o.year)
You may also consider the JPA maxResults option on Query.
Re: Problem in using SQL Keyword in JPQL [message #903158 is a reply to message #899629] Wed, 22 August 2012 05:46 Go to previous message
Hi James,
thank you for your solution, works perfect!
best regards,
Igor
Previous Topic:@OneToMany Annotation problem
Next Topic:Force Insert Query when calling persist()?
Current Time: Sat Jul 26 12:01:57 EDT 2025
Powered by FUDForum. Page generated in 0.09333 seconds
