Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Class 'System' is not found or is abstract
[Acceleo] Class 'System' is not found or is abstract [message #895088] Wed, 11 July 2012 12:31 Go to next message
Hi everyone,
We are trying to generate Lydia code from an xmi file. But we get the error "Class 'System' is not found or is abstract".
SO, we are using our own ecore metamodel. All packages are registered in the generated java file (I read it is not possible to register the metamodel alone when it is made of different packages, but all packages have to be individualy registered).
We use Indigo version.
The input model is an .xmi file. Here is the code we use for registering the factory resource:
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
The heading of the input model is:
<?xml version="1.0" encoding="ASCII"?>
<STRUCT:[b]System[/b] xmi:version="2.0"
    xmlns:STRUCT="http: //zuse.ucc.ie/itobo/structure"
    xmlns:DX="http: //zuse.ucc.ie/itobo/diagnosis"
    xmlns:PL="http: //zuse.ucc.ie/itobo/propositionallogic"
    name="main">
All this packages are registered in the generated java file.
resourceSet.getPackageRegistry().put("http: //zuse.ucc.ie/itobo/structure", org.eclipse.emf.ecore.EcorePackage.eINSTANCE);
However registering everything, the error "class "System" is not found or is abstract" still comes up.
Also, sometimes the error "emtl file is not found" appears (may be significant(?))
Any help will be greatly appreciated.
Cheers
[Updated on: Thu, 12 July 2012 10:35] by Moderator
Re: [Acceleo] Class 'System' is not found or is abstract [message #895367 is a reply to message #895088] Thu, 12 July 2012 11:10 Go to previous messageGo to next message
This means that you are registering the package of the Ecore meta-model "EcorePackage.eINSTANCE" to handle all occurrences of the URI "http: //zuse.ucc.ie/itobo/structure".
You code should look like this:
resourceSet.getPackageRegistry().put("http: //zuse.ucc.ie/itobo/structure", ie.ucc.zuse.package.where.your.emf.code.is.generated.by.the.genmodel.NameOfYourRootPackage.eINSTANCE);
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
[Updated on: Thu, 12 July 2012 11:11] by Moderator
Re: [Acceleo] Class 'System' is not found or is abstract [message #895848 is a reply to message #895367] Mon, 16 July 2012 05:54 Go to previous messageGo to next message
Hi Stephane,
I am a little confused. The project has no genmodel. It has the mtl file, the generated java file, the ecore meta-model and the xmi input model.
Please see here a screenshot of the project explorer and the registerPackages() function in Generate.java:
https: //dl.dropbox.com/u/50566170/Screenshot.png (remove space)
Does the project require a genmodel?
Regards and Thanks,
[Updated on: Mon, 16 July 2012 05:57] by Moderator
Re: [Acceleo] Class 'System' is not found or is abstract [message #895856 is a reply to message #895848] Mon, 16 July 2012 06:33 Go to previous messageGo to next message
Ecore is pretty good but it is not magic.
When you specify
resourceSet.getPackageRegistry().put("...",
you specify that the functionality of the "..." model has been compiled
into the EcorePackage.eINSTANCE. You have therefore specified that six
of your models are identical to the standard Ecore.
You can use dynamic Ecore to avoid genmodel and Java files, but you must
create an EPackage. So something like
Resource resource =
resourceSet.getResource("file:/location/of/hybridautomaton.ecore", true);
EPackage ePackage = (EPackage) resource.getContents().get(0);
EPackage.Registry.INSTANCE.put(ePackage.getNsURI(), ePackage);
for each of your models.
Ed Willink
Re: [Acceleo] Class 'System' is not found or is abstract [message #898065 is a reply to message #895856] Wed, 25 July 2012 13:36 Go to previous messageGo to next message
Thanks Ed,
I added this code:
Resource resource =
            		resourceSet.getResource(URI.createFileURI("./src/org/itobo/modeltotext/common/System.ecore"), true);
But this applies only to the ecore meta-model. How can each ePackake be registered since they are all share the same ecore meta-model path?
Same error "class not found" comes up.
Cheers and Thanks
[Updated on: Wed, 25 July 2012 13:48] by Moderator
Re: [Acceleo] Class 'System' is not found or is abstract [message #898085 is a reply to message #898065] Wed, 25 July 2012 14:31 Go to previous messageGo to next message
On 25/07/2012 18:36, Toni Marin wrote:
> Thanks Ed,
> I have tried adding to the code:
> Resource resource =
> true);
> But this can only be applied for the ecore meta-model (I cannot put a
> path for each ePackage, since they are in System.ecore).
Yes you can. You just need to modify resource.getContents().get(0) to
navigate to them.
> I am still getting the same error of class not found.
> Any thoughts?
> Thanks
Re: [Acceleo] Class 'System' is not found or is abstract [message #898362 is a reply to message #898085] Thu, 26 July 2012 05:29 Go to previous messageGo to next message
Thanks, I tried that with this code:
Resource resource = resourceSet.getResource(URI.createFileURI("./src/org/itobo/modeltotext/common/System.ecore"), true);
for (Iterator iter = resource.getContents().iterator(); iter.hasNext();) {
          	EPackage element = (EPackage) iter.next();
           	resourceSet.getPackageRegistry().put(element.getNsURI(), element);
It only iterates on the main package not entering the sub-packages where the actual classes are (see dl.dropbox.com/u/50566170/Ecore.png).
I know this is more like a java question, but any help is very welcome,
[Updated on: Thu, 26 July 2012 05:46] by Moderator
Re: [Acceleo] Class 'System' is not found or is abstract [message #898389 is a reply to message #898362] Thu, 26 July 2012 06:13 Go to previous messageGo to next message
Try
for (TreeIterator<EObject> tit = resource.getAllContents();
tit.hasNext(); ) {
EObject eObject = tit.next();
if (eObject instanceof EPackage) {
or program the nested descent yourself.
Ed Willink
On 26/07/2012 10:29, Toni Marin wrote:
> Thanks Ed,
> Resource resource =
> true);
> iter.hasNext();) {
> Debugging it, I found out that it only iterates on the main package
> not entering the sub-packages where the actual classes are. (see
> https:// dl.dropbox.com/u/50566170/Ecore.png) (remove space)
> This is more like a java question, but any help is very welcome,
> Thanks
Re: [Acceleo] Class 'System' is not found or is abstract [message #898537 is a reply to message #898389] Thu, 26 July 2012 10:32 Go to previous message
That worked!
Thanks a million,
Antonio
Previous Topic:XPand2 extension problem
Next Topic:[Acceleo] how to create a compiler with xtext and Acceleo ?
Current Time: Sun Jul 27 16:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
