Getting model elements of other file for validation [message #894998] |
Wed, 11 July 2012 07:22  |
Hello everyone,
A short question: I have to model files (A and B for ease). In B I can reference to entities which I declared in A. So it seams that the model of A is known in B. But if I want to validate the model from B by checking for equal names in A I am not able to. In the validator methods I only get delivered the model elements of B by default. That is why my question: How can I get the model elements of file A while the validator methods are called while changing something in model file B?
Thanks again for any answer
Hannes
Re: Getting model elements of other file for validation [message #895019 is a reply to message #895006] |
Wed, 11 July 2012 08:26   |
Thx Ed for your answer - for the rest see below
Ed Merks wrote on Wed, 11 July 2012 07:39Hannes,
Comments below.
On 11/07/2012 1:22 PM, Hannes Müller wrote:
> Hello everyone,
Can't you follow the references in B?
-> My validator starts with the root - so all elements should be reachable.
> by default.
Validators are generally applied to all the contents of each resource.
When you open A directly the validator will validate those, and, if you
have an Xtext nature in the project, the validator will run for each
resource in that project.
-> hm, this sounds like that I need: But if I debug than the followin happens:
A)In A are two measurements (here named ZigZag and Other)
measurements {
measurement ZigZag {
parameter BeginPos{
recalculates {
Customer & Finished ==> NOP;
state transitions {
Customer & Finished& FinishedAction ==> Customer & Finished;
end measurement;
measurement Other{
parameter BeginPos2{
recalculates {
state transitions {
end measurement;
B) in B their is only one measurement
measurements {
parameter BeginPos2 {
recalculates {
Customer & Finished ==> 34;
state transitions {
Customer & Finished & FinishedAction ==> Customer & Finished;
end measurement;
If I make a change in A the validator starts and gets the root element of my model:
Here I get for A that I have one measurements element and two measurement elements. If I change B than I get one measurments element and one measurement element.
Also maybe interesting: The validation method will only be called one time (like I said before - the argument is the root element ...)
I also have other checks for other elements: The effect is the same for other elements! (two recalculates for A and one for B).
> model file B?
Would things in A really become invalid because of changes to B? It
sounds like all the problems should be in B when you change B, unless A
is referencing B...
-> B should be an extension to model A. A should represent the core functionalities and B C and D are individual models which use A and add their specific parts. An Example would be that a normal car has only the core functionalities like lights or wheels and the luxus edition has aircondition. That is the thought behind this.
> Hannes
Re: Getting model elements of other file for validation [message #895031 is a reply to message #895019] |
Wed, 11 July 2012 09:04   |
Hannes,
Comments below.
On 11/07/2012 2:26 PM, Hannes Müller wrote:
> Hello,
>> Hannes,
>> Comments below.
>> > Hello everyone,
>> can > reference to entities which I declared in A. So it seams that
>> the > model of A is known in B. But if I want to validate the model
>> from B > by checking for equal names in A I am not able to. Can't you
>> reachable.
>> B > by default. Validators are generally applied to all the contents
>> of each resource. When you open A directly the validator will
>> validate those, and, if you have an Xtext nature in the project, the
>> validator will run for each resource in that project.
>> happens:
>> measurements {
>> parameter BeginPos{
>> recalculates {
>> state transitions { Customer & Finished&
>> end measurement;
>> measurement Other{
>> parameter BeginPos2{ recalculates {
>> end measurement;
>> measurements {
>> recalculates {
>> state transitions { Customer & Finished &
>> end measurement;
>> element of my model: Here I get for A that I have one measurements
>> > model file B?
Are you saying B references A because B defines a measurement with the
same name as does A? Or is there actually a reference between the two
resources?
>> A is referencing B...
There's no clear answer to any of your questions until you make it clear
how it is that B references A. I don't see anything in your example to
imply there's a reference between them.
>> > Hannes
FUDForum. Page generated in 0.05040 seconds
