Home » Archived » EGL Development Tools » IBM i Program Call under 0.81 M3(Things changed.....)
IBM i Program Call under 0.81 M3 [message #894364] Sun, 08 July 2012 13:53 Go to next message
I am revisiting IBM i program calls and now that 0.81 M3 is out I see that some things have changed.
I really liked that we could invoke a program call from a Rich UI using a syntax that made it appear that we were calling the program from Rich UI client tier. (I know that there was actually a proxy layer in between but it was invisible to the programmer.) I can't seem to figure out how to make that type of call work now that M3 has dropped.
Taking the working example from my video (see http://www.youtube.com/watch?feature=player_embedded&v=6Kt90MVUdCM#!) I made what seemed to be the necessary modifications for 0.81 M3 (using the new @Resource and @StructXXXXX annotations). Here's the modified service code:
service CallRPGService
function hello(name string inout)
    @Resource{uri = "binding:MyConnection"},
    @IBMiProgram {
     	 programName = "MYRPG",
         libraryName = "/QSYS.LIB/*LIBL.LIB/",
         parameterAnnotations = [
            @StructText{length = 40}
end
end
In my Rich UI client I used to be able to do this:
   function varGoButton_onClick(event Event in)
    	call CallRPGService.hello(varNameField.text)
    		using new HttpProxy
    		returning to myCallbackFunction
    		onException myExceptionHandler;
    end
This no longer compiles. The errors are:
IWN.VAL.5727.e 28/13 CallRPGClient - The type of the using expression must be
eglx.jtopen.IBMiConnection. At lint 28 in file \CallRPGProgram\EGLSource\com\dandarnell\client
\CallRPGClient.egl.
IWN.VAL.5729.e 29/7 CallRPGClient - A "returning to" or "onexception" expression is not allowed for a
call to a local function. At lint 29 in file \CallRPGProgram\EGLSource\com\dandarnell\client
\CallRPGClient.egl.
IWN.VAL.5729.e 30/7 CallRPGClient - A "returning to" or "onexception" expression is not allowed for a
call to a local function. At lint 30 in file \CallRPGProgram\EGLSource\com\dandarnell\client
\CallRPGClient.egl.
I don't find an example in the online or product help for invoking an IBM i service function directly from a Rich UI client but the documentation DOES still indicate that this is possible. Question is, how?
--Dan
[Updated on: Mon, 09 July 2012 13:08] by Moderator
Re: IBM i Program Call under .8 M3 [message #894561 is a reply to message #894364] Mon, 09 July 2012 11:26 Go to previous messageGo to next message
Hi Dan,
I'd like to say this is a validation problem, but I need to do more investigation.
Until I determine whether this is a validation problem or limitation, add another service function that just does a call, ie
service CallRPGProgram
    function hello(name string inOut)
	    call this.helloRPG(name);
    end
    function helloRPG(name string(40) inOut){
        @IBMiProgram{
        	isServiceProgram = false
    end
end
Based on your other post about the call defect I think you already figured this out and got stuck because of a generation error.
BTW we are now supporting so you will see that I modified your parameter to use string(40) instead of the StructText{length = 40} annotation.
regards,
Joe
Re: IBM i Program Call under .8 M3 [message #894569 is a reply to message #894561] Mon, 09 July 2012 11:50 Go to previous messageGo to next message
Thanks, Joe. I was actually finishing up an article for a magazine this past weekend (my deadline is today) and decided to pull in M3 to make sure everything still worked and to modify my examples for the changes in syntax .... that's when everything went sideways.
I would hate to lose the ability to go "directly" from a Rich UI client to an IBM i program call function -- not just because my article covers this but mainly because it is a capability not found in any of the tools and languages that compete with EDT. It is a fantastic way to simply access IBM i resources.
Long story short, I am hoping that you will be able to provide a near-term fix of some sort for this issue. I have already informed my editor that I won't be meeting my deadline today but I sure would like to be able to wrap up my article. I think EDT can use the exposure and I know the IBM i community will benefit from EDT if they can see how great the IBM i support is!
--Dan
Re: IBM i Program Call under .8 M3 [message #894643 is a reply to message #894569] Mon, 09 July 2012 19:52 Go to previous messageGo to next message
Hi Dan,
This was a defect. I opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=384668. I've committed a fix and you should be able to pick it up after the build runs @9.
thanks,
Joe
Re: IBM i Program Call under .81 M3 [message #894819 is a reply to message #894643] Tue, 10 July 2012 12:10 Go to previous messageGo to next message
Many thanks, Joe. This and the other fix should get me back on track. Do you think that both fixes will make it into the 0.81 final?
--Dan
Re: IBM i Program Call under .81 M3 [message #894993 is a reply to message #894819] Wed, 11 July 2012 07:09 Go to previous messageGo to next message
Hi Dan,
Yes both fixes are already in, so they will be in 0.8.1 final.
regards,
Joe
Re: IBM i Program Call under .81 M3 [message #895149 is a reply to message #894993] Wed, 11 July 2012 15:54 Go to previous message
Excellent!
Previous Topic:Application Development Cover Story -- No EGL?!
Next Topic:Set compiler options in EGL New Package wizard
Current Time: Mon Sep 15 05:05:14 EDT 2025
Powered by FUDForum. Page generated in 0.05417 seconds
