Home » Modeling » EMF » [CDO] Exception on pre-built binary package
[CDO] Exception on pre-built binary package [message #894952] Wed, 11 July 2012 04:43 Go to next message
I downloaded the pre-built package for windows and just ran it.
Then I connected through the CDO Sessions view from Eclipse 4.
When I connect I get FactoryNotFoundException (see the attached image).index.php/fa/10659/0/
Is that normal?
Re: [CDO] Exception on pre-built binary package [message #894957 is a reply to message #894952] Wed, 11 July 2012 04:55 Go to previous messageGo to next message
By the way the exception is thrown again and again every few seconds.
Re: [CDO] Exception on pre-built binary package [message #895059 is a reply to message #894957] Wed, 11 July 2012 10:53 Go to previous messageGo to next message
Am 11.07.2012 10:55, schrieb Federico Tomassetti:
Hmm, that's kind of odd, but in no way hindering evaluation. If, on the client-side, you close the CDO Administration
view it should go away (fix1). You can also fix it by manually deploying the org.eclipse.emf.cdo.server.admin bundle to
the server (fix2).
The reason for this behaviour is that the new CDO Administration view periodically tries to establish a cdo-admin
protocol connection to all configured servers and list their repositories. This bug describes the new CDOAdmin API:
381472: Design a repository administration API
https://bugs.eclipse.org/bugs/show_bug.cgi?id=381472
These types form the client-side API:
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClient.java
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClientManager.java
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClientRepository.java
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClientUtil.java
Can you please submit a bugzilla so that I can fix the your current problem in the next maintenance build (fix1)?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Exception on pre-built binary package [message #895060 is a reply to message #895059] Wed, 11 July 2012 10:54 Go to previous messageGo to next message
Am 11.07.2012 16:53, schrieb Eike Stepper:
Sorry, I meant fix2 ;-)
Cheers
/Eike
Re: [CDO] Exception on pre-built binary package [message #981340 is a reply to message #895060] Mon, 12 November 2012 05:43 Go to previous message
I have the following trace when I call CdoAdmin.createRepository :
net4j-Thread-5 [org.eclipse.internal.net4j.buffer.BufferPool] Obtained Buffer@204[INITIAL]
net4j-Thread-5 [org.eclipse.net4j.signal.SignalProtocol] Put signal id 4
[WARN] A problem occured while notifying client SignalProtocol[cdo-admin]
	at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServerRepository.write(CDOAdminServerRepository.java:197)
	at org.eclipse.emf.cdo.server.internal.admin.protocol.RepositoryAddedRequest.requesting(RepositoryAddedRequest.java:35)
	at org.eclipse.net4j.signal.Request.doExtendedOutput(Request.java:67)
	at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
	at org.eclipse.net4j.signal.Request.doExecute(Request.java:59)
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:440)
	at org.eclipse.net4j.signal.Request.sendAsync(Request.java:53)
	at org.eclipse.emf.cdo.server.internal.admin.protocol.CDOAdminServerProtocol.sendRepositoryAdded(CDOAdminServerProtocol.java:51)
	at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServer.repositoryAdded(CDOAdminServer.java:164)
	at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServer$1.onAdded(CDOAdminServer.java:52)
	at org.eclipse.net4j.util.container.ContainerEventAdapter$1.added(ContainerEventAdapter.java:50)
	at org.eclipse.net4j.util.container.ContainerEvent.accept(ContainerEvent.java:113)
	at org.eclipse.net4j.util.container.ContainerEventAdapter.notifyContainerEvent(ContainerEventAdapter.java:46)
	at org.eclipse.net4j.util.container.ContainerEventAdapter.notifyEvent(ContainerEventAdapter.java:35)
	at org.eclipse.net4j.util.event.Notifier.fireEventSafe(Notifier.java:146)
	at org.eclipse.net4j.util.event.Notifier.fireEvent(Notifier.java:110)
	at org.eclipse.net4j.util.event.Notifier.fireEvent(Notifier.java:86)
	at org.eclipse.net4j.util.container.ManagedContainer.fireEvent(ManagedContainer.java:478)
	at org.eclipse.net4j.util.container.ManagedContainer.putElement(ManagedContainer.java:361)
	at org.eclipse.net4j.util.container.ManagedContainer.putElement(ManagedContainer.java:337)
	at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:207)
	at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServer.doCreateRepository(CDOAdminServer.java:110)
	at org.eclipse.emf.cdo.spi.common.admin.AbstractCDOAdmin.createRepository(AbstractCDOAdmin.java:105)
	at org.eclipse.emf.cdo.server.internal.admin.protocol.CreateRepositoryIndication.responding(CreateRepositoryIndication.java:54)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	at java.lang.Thread.run(Thread.java:662)
My client code is :
package ........model.tests;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import junit.framework.Assert;
import org.eclipse.emf.cdo.admin.CDOAdminClient;
import org.eclipse.emf.cdo.admin.CDOAdminClientUtil;
import org.eclipse.emf.cdo.common.admin.CDOAdmin;
import org.eclipse.emf.cdo.common.admin.CDOAdminRepository;
import org.eclipse.emf.cdo.net4j.CDONet4jSession;
import org.eclipse.emf.cdo.net4j.CDONet4jSessionConfiguration;
import org.eclipse.emf.cdo.net4j.CDONet4jUtil;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.net4j.Net4jUtil;
import org.eclipse.net4j.connector.IConnector;
import org.eclipse.net4j.tcp.TCPUtil;
import org.eclipse.net4j.util.container.IPluginContainer;
import org.eclipse.net4j.util.io.IOUtil;
import org.eclipse.net4j.util.lifecycle.ILifecycle;
import org.eclipse.net4j.util.lifecycle.LifecycleEventAdapter;
import org.junit.BeforeClass;
import org.junit.Test;
public class TestCdoClient {
	private static IConnector connector;
	public static final long DEFAULT_TIMEOUT = 500;
	private static final String ADMIN_HANDLER_TYPE = ConnectionPackage.eNS_PREFIX;
	@BeforeClass
	public static void init() {
		// The following lines are not needed if the extension
		// registry (OSGi/Equinox) is running
		Net4jUtil.prepareContainer(IPluginContainer.INSTANCE);
		TCPUtil.prepareContainer(IPluginContainer.INSTANCE);
		connector = (IConnector) IPluginContainer.INSTANCE.getElement( //
				"org.eclipse.net4j.connectors", // Product group
				"tcp", // Type
				"localhost:2036");
	@Test
	public void test() throws IOException, InterruptedException {
		CDOAdmin admin = openAdmin(null);
		try {
			int size = admin.getRepositories().length;
			.. repo = ...Factory.eINSTANCE
					.create...Repository();
			repo.setDatabaseHostName("localhost");
			final String value = "cdoTestClientRepo"
					+ System.currentTimeMillis();
			repo.setName(value);
			Map<String, Object> propperties = new HashMap<String, Object>();
			EList<EAttribute> attributes = repo.eClass().getEAttributes();
			for (EAttribute eAttribute : attributes) {
				propperties.put(eAttribute.getName(), repo.eGet(eAttribute));
			CDOAdminRepository repo2 = null;
			try {
				// FIXME BUG CDO
				repo2 = admin.createRepository(value, ADMIN_HANDLER_TYPE,
						propperties);
			} catch (Exception e) {
				e.printStackTrace();
				// FIXME BUG CDO - Always occurred
			} finally {
				disposeAdmin(admin);
				CDOAdminRepository[] repos = admin.getRepositories();
				for (CDOAdminRepository cdoAdminRepository : repos) {
					if (cdoAdminRepository.getName().equals(repo.getName())) {
						repo2 = cdoAdminRepository;
			Assert.assertNotNull(repo2);
			Assert.assertEquals(value, repo2.getName());
			Assert.assertEquals(size + 1, admin.getRepositories().length);
			repo2.delete(ADMIN_HANDLER_TYPE);
			Assert.assertEquals(null, admin.getRepository(value));
			Assert.assertEquals(size, admin.getRepositories().length);
		} finally {
			cleanup(admin);
	private CDOAdmin openAdmin(Object object) throws InterruptedException {
		String url = connector.getURL();
		final CDOAdminClient admin = CDOAdminClientUtil.openAdmin(url,
				DEFAULT_TIMEOUT);
		long timeout = System.currentTimeMillis() + DEFAULT_TIMEOUT + 10;
		while (System.currentTimeMillis() < timeout && !admin.isConnected()) {
			Thread.sleep(10);
		return admin;
	private void cleanup(CDOAdmin admin) {
		connector.close();
	private void disposeAdmin(CDOAdmin admin) {
		IOUtil.closeSilent(admin);
I have to dispose CDOAdmin and reopen it to conturn this excepion.
I've always a Timeout excetion on client site that I catch, but it will be difficult to maintain an efficient code in my UI application.
Previous Topic:Unexpected meta-model reloading improvement
Next Topic:EMF Update Sites
Current Time: Sat Jul 26 11:22:30 EDT 2025
Powered by FUDForum. Page generated in 1.07528 seconds
