BIRT report w/ parameter fails when ? placed in SQL where clause [message #894878] |
Tue, 10 July 2012 17:35  |
Hello all!
I'm brand new to BIRT and am creating a simple report with a parameter for the user to enter an "Environment" string, I default the parameter to %. When I set the parameter up, there are no issues, but when I put "LIKE ?" in place of "LIKE '%'" in the where clause of the query, I get an exception when running the report, previewing the report or previewing the results in the dataset:
org.eclipse.birt.data.engine.core.DataException: Failed to prepare the query execution for the data set: t_host
Cannot get the type for parameter: 1.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot get parameter type.
SQL error #1:Unsupported feature
java.sql.SQLException: Unsupported feature
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:345)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:159)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:142)
at org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelper.executeQuery(QueryExecutionHelper.java:136)
at org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelper.executeQuery(QueryExecutionHelper.java:118)
at org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelper.executeQuery(QueryExecutionHelper.java:102)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRuntimeMetaData(DataSetMetaDataHelper.java:194)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRealMetaData(DataSetMetaDataHelper.java:153)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getDataSetMetaData(DataSetMetaDataHelper.java:115)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.refreshMetaData(DataSetMetaDataHelper.java:382)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.refreshMetaData(DataRequestSessionImpl.java:415)
at org.eclipse.birt.report.designer.data.ui.dataset.ExternalUIUtil.updateColumnCache(ExternalUIUtil.java:108)
at org.eclipse.birt.report.designer.data.ui.providers.DefaultDataServiceProvider.updateColumnCache(DefaultDataServiceProvider.java:114)
at org.eclipse.birt.report.designer.internal.ui.data.DataService.updateColumnCache(DataService.java:140)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetUIUtil.updateColumnCache(DataSetUIUtil.java:98)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetEditor.okPressed(DataSetEditor.java:685)
at org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog.buttonPressed(AbstractPropertyDialog.java:650)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.providers.EditableDataSetNodeProvider.performEdit(EditableDataSetNodeProvider.java:102)
at org.eclipse.birt.report.designer.internal.ui.views.DefaultNodeProvider.performRequest(DefaultNodeProvider.java:442)
at org.eclipse.birt.report.designer.internal.ui.views.actions.EditAction.doAction(EditAction.java:90)
at org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.birt.report.designer.internal.ui.views.RenameListener.doubleClick(RenameListener.java:214)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1477)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the type for parameter: 1.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:55)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:96)
at org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData.getRuntimeParameterType(ParameterMetaData.java:237)
at org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData.<init>(ParameterMetaData.java:97)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.mergeParamHintsWithMetaData(PreparedStatement.java:1674)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getParameterMetaData(PreparedStatement.java:1525)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.setInputParameterBinding(DataSourceQuery.java:1103)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.addParameterDefns(DataSourceQuery.java:574)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:290)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:442)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:341)
... 69 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot get parameter type.
at org.eclipse.birt.report.data.oda.jdbc.ParameterMetaData.getParameterType(ParameterMetaData.java:161)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaParameterMetaData.getParameterType(OdaParameterMetaData.java:177)
at org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData.getRuntimeParameterType(ParameterMetaData.java:233)
... 77 more
Caused by: java.sql.SQLException: Unsupported feature
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:146)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:208)
at oracle.jdbc.driver.DatabaseError.throwUnsupportedFeatureSqlException(DatabaseError.java:499)
at oracle.jdbc.driver.OracleParameterMetaData.getParameterType(OracleParameterMetaData.java:157)
at org.eclipse.birt.report.data.oda.jdbc.ParameterMetaData.getParameterType(ParameterMetaData.java:155)
... 79 more
config info:
eclipse.buildId=I20120608-1400
java.version=1.6.0_18
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.reporting.product -clean
Similar reports with parameters in our environment work just fine with Eclipse Indigo/BIRT 3.7.1/Oracle 10.2 JDBC, and when I open them in my instance of Eclipse/BIRT, the parameter problem appears.
Incidently, I created a datasource/dataset connected to a MySQL DB with my Eclipse Juno/BIRT 4.2.0/MySQL 5.0 JDBC and parameters worked with no problems.
I'm at a loss to figure out why parameters are not working while connected to an Oracle DB using either the 10.2 or 11.1 JDBC driver.
Brad
FUDForum. Page generated in 0.09460 seconds
