Home » Modeling » TMF (Xtext) » Cross References are working only in a specific parts of the model - why?
Cross References are working only in a specific parts of the model - why? [message #894841] Tue, 10 July 2012 13:44 Go to next message
Hi everyone,
I have a language posted below. My problem is the following: I "declare" formulas in a specific parameter for example:
parameter BeginPos{
recalculates
Mta & init ==> formula myFormula2 : BeginPos + 2;
If I know want to reuse my formula I work with cross references.
Recalculate:
... '==>' (recalculateFormula = RecalculateFormula | 'reuse' resusedRecalculateFormula = [RecalculateFormula]) ';'
The DSL would look like this ...
knownParameter BeginPos {
recalculates {
Customer & init ==> reuse myFormula2;
But because of some unknown reason xtext can not resolve the reference to myFormula2???
If I do declare a formula in the scope of a "reused" Parameter (a cross reference to a known parameter - see the example DSL below) -> than xtext CAN RESOLVE the formulas!?
recalculates {
Customer & inProgress ==> formula myFormula2 : 2 + 3 4;
recalculates {
Does anyone has a clue why this behaves this way? I would be grateful for any hint.
Thx in advance
Hannes
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl // here is the DSL URI - but I am still not allowed to add URIs in the forum ...
DomainModel:
{DomainModel}
supportedUsers = SupportedUserStates
supportedProgressStates = SupportedProgressStates
supportedActions = SupportedStateChangingActions
measurementsWithParmeters += MeasurementsWithParametersAndStateTransitions+
SupportedUserStates:
'users' '{' supportedUserStates += SupportedUserState (',' supportedUserStates += SupportedUserState)*'}'
SupportedUserState:
name = ID
SupportedProgressStates:
'progresses' '{'supportedProgressStates += SupportedProgressState (',' supportedProgressStates += SupportedProgressState)*'}'
SupportedProgressState:
name = ID
SupportedStateChangingActions:
'actions' '{'supportedStateChangingActions += StateChangingAction (',' supportedStateChangingActions += StateChangingAction)*'}'
StateChangingAction:
name = ID
MeasurementsWithParametersAndStateTransitions:
'measurements' '{'measurementsWithParametersAndStateTransitions += MeasurementWithParametersAndTransition 'end measurement;' (measurementsWithParametersAndStateTransitions += MeasurementWithParametersAndTransition 'end measurement;')* '}'
MeasurementWithParametersAndTransition:
measurement = Measurement '{' (parametersWithRecalulate += ParameterWithRecalculate)+ stateTransitions = StateTransitions '}'
Measurement:
'measurement' name = ID
ParameterWithRecalculate:
// new parameter should be declared or know parameter which already has some formulas
('parameter' name = ID (immutable = "immutable")?| 'knownParameter' paramWithRecal = [ParameterWithRecalculate])
'{' 'recalculates' '{' (recalculates += Recalculate)+ '}''}'
Recalculate:
userStates += [SupportedUserState] '&' progressStates += [SupportedProgressState]
('&&' userStates += [SupportedUserState] '&' progressStates += [SupportedProgressState])* '==>' (recalculateFormula = RecalculateFormula | 'reuse' resusedRecalculateFormula = [RecalculateFormula]) ';'
// the keyword reused (could be an other name) is mandatory necessary because else the parser cannot decide what to chose (ambiguity)
RecalculateFormula:
('formula 'name = ID':')? (complexFormula = Expression | specialFormula = SpecialFormula)
enum SpecialFormula:
NOP="NOP" // signals null object pattern
Expression:
Addition
Addition returns Expression:
Multiplication (({Plus.left=current} '+' | {Minus.left=current} '-') right=Multiplication)*
Multiplication returns Expression:
PrimaryExpression (({Multi.left=current} '*' | {Div.left=current} '/') right=PrimaryExpression)*
PrimaryExpression returns Expression:
leftBracktet = '(' expression = Expression rightBracket =')' | parameter = [ParameterWithRecalculate] | number = Number // the features left and right brackets are a "trick" to be able to recognize if the current formula is or is not surrounded with brackets while code generation
Number:
integer = INT | double = Double
Double:
predecimalNumber = INT '.' decimalNumber = INT
enum FormulaOperator:
PLUS = '+' | MINUS = '-' | MULTIPLIKATION = '*' | DIVISION = '/'
StateTransitions:
'state transitions {' (stateTransitions += StateTransition ';')+'}'
StateTransition:
stateTransitionConditions += StateTransitionContition ('&&' stateTransitionConditions += StateTransitionContition)* '==>' userStateNEW = [SupportedUserState] '&' progressStateNEW = [SupportedProgressState]
StateTransitionContition:
userStateOLD = [SupportedUserState] '&' progressStateOLD = [SupportedProgressState] '&' stateChangingAction = [StateChangingAction]
[Updated on: Tue, 10 July 2012 13:48] by Moderator
Re: Cross References are working only in a specific parts of the model - why? [message #894842 is a reply to message #894841] Tue, 10 July 2012 13:49 Go to previous messageGo to next message
sounds like a qualified name problem. xtext by default builds names like
parentName.childName => it will not work if you write ref=[Sometype] since this is short for ref=[Sometype|ID] and . (dot) is not allowed in ID
~Christian
Re: Cross References are working only in a specific parts of the model - why? [message #894958 is a reply to message #894842] Wed, 11 July 2012 04:55 Go to previous messageGo to next message
First thank you Christian for your answer Smile
Ok, the first thing I do not understand is, that 'knownParameter' paramWithRecal = [ParameterWithRecalculate] works in my DSL and 'reuse' resusedRecalculateFormula = [RecalculateFormula] not - I mean it looks equal! And ParameterWithRecalculate also should have a qualified name like parentName.childName (it also has a parent) - or am I wrong here? What is the different of this two?
Also the tutorial example looks equal ('extends' superType = [Entity])
The second question is how can I solve my problem because I want reusable formulas.
Thx in advance for any hint
Hannes
Re: Cross References are working only in a specific parts of the model - why? [message #894982 is a reply to message #894958] Wed, 11 July 2012 06:35 Go to previous messageGo to next message
Hi the first has no parent with a name the second has. If you want to
use simple names in general bind simplenameprovider as
iqualifiednameprovider - else write a custom
defaultdeclarativenameprovider that gives the element a simple name.
Or you change the grammar to
Xxx=[sometype|FQN]
With
FQN: ID ("." ID)*;
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Cross References are working only in a specific parts of the model - why? [message #895022 is a reply to message #894982] Wed, 11 July 2012 08:43 Go to previous message
Thanks Christian,
I work with the FQN variant and it works. I am happy Smile
The thread can be closed.
Previous Topic:JVMField with primitive type
Next Topic:OCL: Iterate over code lines
Current Time: Sun Jul 27 00:37:32 EDT 2025
Powered by FUDForum. Page generated in 0.05243 seconds
