Home » Modeling » TMF (Xtext) » This is a bug with the quikfix?
This is a bug with the quikfix? [message #894501] Mon, 09 July 2012 08:57 Go to next message
Hi!
I'm trying the quickfix feature of xtext and I found the following problem.
If I use ISemanticModification this way ...
acceptor.accept(issue, "Change to "+ parentStateName + "." + viewName, "Replace the state ID for a valid View name.", "upcase.png", new ISemanticModification() {
	public void apply(EObject element, IModificationContext context) throws Exception {
		// sabemos que es un state de tipo view
		ScxmlStateType state = (ScxmlStateType) element;
		state.setName("\""+parentStateName + "." + viewName+"\"");
And use the quickfix in the second state (to fix the ERRONEUS_ID) in this text:
<state id="SecondOp" mymw:category="UseCase" initial="SecondOp.suma">
   <!-- Presentación suma -->
   <state id="ERRONEUS_ID" mymw:category="View">
     <!-- llamando a un método de una clase concreta al enviar un formulario -->
      <transition event="mySubmit.onsubmit" target="SecondOp.resultado">
The pre-and post comments to the line where I do the quickfix disappear! Confused The result...
      <state id="CORRECT_ID" mymw:category="View">
If I use IModification() this does not happen (the comments not disappear)...
acceptor.accept(issue, "Change to "+ parentStateName + "." + viewName, "Replace the state ID for a valid View name.", "upcase.png", new IModification() {
	public void apply(IModificationContext context) throws BadLocationException {
		IXtextDocument xtextDocument = context.getXtextDocument();
	        xtextDocument.replace(issue.getOffset(), issue.getLength(), "\""+parentStateName + "." + viewName+"\"");
Any idea that could be happening?
Thanks!!
[Updated on: Tue, 10 July 2012 02:59] by Moderator
Re: This is a bug with the quikfix? [message #894608 is a reply to message #894501] Mon, 09 July 2012 15:35 Go to previous messageGo to next message
Maybe you can complete your post? It seems to be truncated before
reaching a question.
Am 09.07.12 14:57, schrieb Vil Lpz:
> Hi!
> Exception {
> And use the quickfix in this text:
> <state id="ERONEUS_ID" mymw:category="View">
Re: This is a bug with the quikfix? [message #894683 is a reply to message #894608] Tue, 10 July 2012 03:00 Go to previous messageGo to next message
Hi!
I think it´s ok now.
The question is...
Any idea about why, if I use ISemanticModification, the comment lines before and after the line where I use the quckfix disappear?
Thank you very much for the help.
Regards.
Re: This is a bug with the quikfix? [message #895466 is a reply to message #894501] Fri, 13 July 2012 03:26 Go to previous messageGo to next message
Hey.
Nobody has any idea where it may be the problem?
a greeting
Re: This is a bug with the quikfix? [message #895501 is a reply to message #894683] Fri, 13 July 2012 05:51 Go to previous messageGo to next message
Yes,
The comments are stored in the node model as belonging to the semantic
object you modify. After the semantic modification, the partial parsing
replaces the semantic object (and all its children in the AST) with a
new instance. Seems like the nodes containing the comments get lost.
Fell free to file a bug.
If you want to avoid that, use textual IModifications as a workaround.
Am 10.07.12 09:00, schrieb Vil Lpz:
> Hi!
> The question is...
> Regards.
Re: This is a bug with the quikfix? [message #895565 is a reply to message #895466] Fri, 13 July 2012 11:02 Go to previous messageGo to next message
Am 13.07.12 09:26, schrieb Vil Lpz:
> Hey.
> a greeting
It's not possible to answer your question given the sparse information
that you provide. Jan's answer is still valid. If you fear that you
stumbled accross a bug that leads to lost comments, please file a ticket
with a reproducable testcase attached.
Sebastian
Re: This is a bug with the quikfix? [message #895817 is a reply to message #895501] Mon, 16 July 2012 03:54 Go to previous messageGo to next message
thank you very much for the help!
Greetings.
Re: This is a bug with the quikfix? [message #895829 is a reply to message #895817] Mon, 16 July 2012 04:41 Go to previous message
Hello.
I attached the Code of a small project that reproduces the error that said, to see if someone can take a look.
To test run and create a file *.Test with (for example)
<?xml  ?>
  <scxml initial="test2_test" name='myname' >
   <!-- comment-->
   <state	id="test2_test" mymw:category="bad">
   <!-- comment -->
   </state>
</scxml>
When "mymw:category="bad"" is fixed comment disappear...
Thank you very much for your attention.
  • Attachment: test.zip
    (Size: 219.01KB, Downloaded 167 times)
Previous Topic:xbase generation exception
Next Topic:[xbase] How to parse Xbase expressions in Java code?
Current Time: Sun Jul 27 02:10:00 EDT 2025
Powered by FUDForum. Page generated in 0.98022 seconds
