Help! com.ibm.j9ddr.InvalidDataTypeException: U_32 contains value larger than Integer.MAX_VALUE [message #894200] |
Sat, 07 July 2012 10:36  |
at com.ibm.j9ddr.vm24.types.U32.intValue(U32.java:116)
at com.ibm.j9ddr.vm24.view.dtfj.java.DTFJJavaField.<init>(DTFJJavaField.java:65)
at com.ibm.j9ddr.vm24.view.dtfj.java.DTFJJavaFieldInstance.<init>(DTFJJavaFieldInstance.java:36)
at com.ibm.j9ddr.vm24.view.dtfj.java.DTFJJavaClass.getDeclaredFields(DTFJJavaClass.java:193)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.exploreObject(DTFJIndexBuilder.java:6610)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.processHeapObject(DTFJIndexBuilder.java:3429)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder.java:2039)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(SnapshotFactoryImpl.java:209)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnapshot(SnapshotFactoryImpl.java:120)
at org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(SnapshotFactory.java:145)
at org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDumpJob.java:83)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
FUDForum. Page generated in 0.09216 seconds
