Maven Build : ArrayIndexOutOfBoundsException [message #894125] |
Fri, 06 July 2012 14:33  |
I am running Maven 3 build on hudson slave and getting below exception. This started happening after moving to JDK 1.7. Any help is appreciated.
[INFO] Using Maven 3 installation: Maven-3
[INFO] Checking Maven 3 installation environment
[platform] $ /opt/install/apps/maven/current/bin/mvn --help
[INFO] Checking Maven 3 installation version
[platform] $ /opt/install/apps/maven/current/bin/mvn --version
[INFO] Detected Maven 3 installation version: 3.0.4
[DEBUG] Waiting for connection on port: 58977
[platform] $ /opt/install/apps/maven/current/bin/mvn clean deploy -V -B -DHUDSON=true -Dmaven.ext.class.path=/home/hudson/maven/slavebundle/resources:/home/hudson/maven/slavebundle/lib/maven3-eventspy-3.0.jar:/home/hudson/slave.jar -Dhudson.eventspy.port=58977 -Dmaven.repo.local=/home/hudson/platform/.maven/repo -f parent/pom.xml -N -q -U
[ERROR] Failure: java.lang.ArrayIndexOutOfBoundsException: 0
FATAL: java.lang.ArrayIndexOutOfBoundsException: 0
org.hudsonci.utils.tasks.OperationFailure: java.lang.ArrayIndexOutOfBoundsException: 0
at org.hudsonci.utils.tasks.PerformOperation.execute(PerformOperation.java:75)
at org.hudsonci.maven.plugin.builder.MavenBuilder.perform(MavenBuilder.java:169)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:630)
at hudson.model.Build$RunnerImpl.build(Build.java:175)
at hudson.model.Build$RunnerImpl.doRun(Build.java:137)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:429)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
at hudson.remoting.RemoteInvocationHandler$RPCRequest.choose(RemoteInvocationHandler.java:295)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:273)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:258)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:218)
at hudson.remoting.UserRequest.perform(UserRequest.java:114)
at hudson.remoting.UserRequest.perform(UserRequest.java:48)
at hudson.remoting.Request$2.run(Request.java:283)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
FUDForum. Page generated in 0.06706 seconds
