Home » Archived » Jubula » Can't open jubula in my VM(Jubula doesn't run)
Can't open jubula in my VM [message #894070] Fri, 06 July 2012 10:28 Go to next message
I just installed Jubula in my Ubuntu VM, but Jubula won't open and won't run at all. I also try to start the AUT Agent but same result. I tried to re-install but I have the same results. I do not know if I am missing something or what. I hope someone can help me. I noticed that I had error log file, but I am not sure what it means. I have attached the error log.
I appreciate the help.
Oscar Trejo
[Updated on: Fri, 06 July 2012 10:31] by Moderator
Re: Can't open jubula in my VM [message #894684 is a reply to message #894070] Tue, 10 July 2012 03:05 Go to previous messageGo to next message
It looks like Jubula crashes while trying to initialize SWT, possibly while trying to load necessary GTK libraries. There's a couple of factors that might be contributing to the problem:
  • What variant (ex. Ubuntu, Kubuntu, Xubuntu, Lubuntu, etc.) and version (ex. 12.04) of Ubuntu are you using? If you're using a variant like Kubuntu, then it's possible that GTK is not installed.
  • Is your Ubuntu 32- or 64-bit? Jubula standalone is 32-bit, so if you are using a 64-bit OS, then certain 32-bit libraries may be missing.
- Zeb
Re: Can't open jubula in my VM [message #895941 is a reply to message #894684] Mon, 16 July 2012 11:07 Go to previous message
Thanks Zeb. I was missing some 32-bit libraries in my VM. After installing them, Jubula worked just fine.
Again, thanks.
Previous Topic: Problem installing jubula: standalone setup.exe fails
Next Topic:Next GUIdancer/Jubula Training Course
Current Time: Wed Jul 23 04:37:26 EDT 2025
Powered by FUDForum. Page generated in 0.23990 seconds
