Home » Eclipse Projects » Rich Client Platform (RCP) » How to ad commands to views with specific secondary view id
How to ad commands to views with specific secondary view id [message #894025] Fri, 06 July 2012 08:31 Go to next message
I am adding commands to views using commands framework. I want to know how to add commands to menus/toolbars for specific views with a specific secondary id?
Re: How to ad commands to views with specific secondary view id [message #894150 is a reply to message #894025] Fri, 06 July 2012 19:38 Go to previous message
Hi Tankut,
a command itself is always independend from the UI(menus/toolbars).
It just defines certain command/action in an abstract way.
The thing you really can add to a View is a menu extension.
On that menuContribution in the plugin.xml you can add a visibleWhen flag, where you can define the conditions for showing the menuContribution.
          <visibleWhen
                checkEnabled="false">
            <with
                  variable="activePart">
               <test
                     property="link to your PropertyTester, which checks the secondary id of the activePart" args="specialSecondaryId1,specialSecondaryId2,specialSecondaryId3">
               </test>
            </with>
          </visibleWhen>
Your PropertyTester could be something like this:
public class SecondaryIdTester extends PropertyTester {
    public boolean test(Object receiver, String property, Object[] args,
            Object expectedValue) {
        boolean testSucceeds = false;
        if(receiver instanceof YourView){
              String secondaryId = ((YourView)receiver).getViewSite().getSecondaryId();
            for(Object arg : args){
                 if(secondaryId.equals(arg)){
                      testSucceeds = true;
        return testSucceeds;
A good overview concerning the usage of PropertyTesters can be found here:
http://wiki.eclipse.org/Command_Core_Expressions#Expressions_and_the_Command_Framework
I hope this helps you and do not hesitate to ask again, if anything is unclear or you need further information.
Simon
[Updated on: Fri, 06 July 2012 19:47] by Moderator
Previous Topic:org.eclipse.ui issue
Next Topic:RCP-App asTest-Tool for a third-party-library ...
Current Time: Thu Jul 17 14:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.10554 seconds
