Home » Modeling » TMF (Xtext) » IJvmModelInferrer and Generation of Java files outside of Eclipse model project
IJvmModelInferrer and Generation of Java files outside of Eclipse model project [message #893990] Fri, 06 July 2012 06:55 Go to next message
My language is based on Xbase grammar and is similar to the Xtext domainmodel example.
I use an IJvmModelInferrer to generate two kinds of Java classes from the model:
* Java interface classes for entities
* and classes implementing these interfaces
Alle generated files are written by EclipseResourceFileSystemAccess2 to src-gen folder in the same Eclipse project (the project with the model file).
Is it possible to generate files to different Eclipse projects or even to a pre-configured file system locations outside of Eclipse workspace?
The following project structure is desired:
  • model-project/src/model.dsl
  • api-project/src-gen/x/y/z/Entity.java
  • impl-project/src-gen/x/y/z/EntityImpl.java
[Updated on: Fri, 06 July 2012 06:57] by Moderator
Re: Jvm [message #894015 is a reply to message #893990] Fri, 06 July 2012 08:04 Go to previous message
hi you would have to customize JvmModelGenerator to use different outlets + a custom IOutputConfigurationProvider to provide these different outlets
~Christian
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
[Updated on: Fri, 06 July 2012 08:49] by Moderator
Previous Topic:Reference to external project
Next Topic:XMLBeautifier uses wrong line separator
Current Time: Sun Jul 06 13:40:33 EDT 2025
Powered by FUDForum. Page generated in 0.02132 seconds
