Home » Modeling » TMF (Xtext) » Xcore - magic content assist for XBlockExpression
Xcore - magic content assist for XBlockExpression [message #893997] Fri, 06 July 2012 07:22 Go to next message
i am impressed about the content assist of Xcores XBlockExpression.
Inside an operation (XBlockExpression) xReferences can be accessed by contentassist. For normal JVMTypeReference are addressed by content assist of a XBlockExpression.
class Library {
	contains Book[*] books opposite library
	op Int getBooksCount(){
		return books.size
But i wonder how it works. I spent hours to find out and have been setting a lot of breakpoints in the code to find the proper piece of code that is responsible to provide an XReference instead of a JVMTypeReference.
First i thought that the generated java code is used... But i suppressed the code generation by a "compile error" in the xcore file and the content assist still works.
I think there will be done some kind of mapping or something.
Can anybody give me a hint which parts of the code are responsible doing this? Then i can continue browsing the underlying source.
Thanks in advance for your help.
And thanks to Xcore team providing such an interesting and really reusable issue!
Best,
Florian Pirchner
Re: Xcore - magic content assist for XBlockExpression [message #894009 is a reply to message #893997] Fri, 06 July 2012 07:42 Go to previous messageGo to next message
Florian,
A *.xcore resources infers the Jvm* things that will be generated
(XcoreJvmInferrer) and those things are in scope within the bodies of
operations. You can see all the inferred things in the hover
information for any construct in the Xcore source. So, for example, the
resource knows there is a generated interface and implementations for an
XClass with accessor methods like getX which in Xbase can be accessed as
if it were a field. If you open the *.xcore resource with EMF's
reflective editor, (Open With->Other...->Sample Reflective Ecore Model
Editor) you can see all the inferred content, e.g., the Ecore model, the
GenModel, and all the Jvm types model instances; it's quite a useful and
interesting feature.
On 06/07/2012 1:22 PM, Florian Pirchner wrote:
> class Library {
> return books.size
> JVMTypeReference.
> reusable issue!
> Best,
> Florian Pirchner
Re: Xcore - magic content assist for XBlockExpression [message #894081 is a reply to message #894009] Fri, 06 July 2012 10:50 Go to previous messageGo to next message
Hi Ed,
thanks a lot for that input.
I explored the created .xcore file with the reflective editor and could find the JVMElements.
Really interesting approach. You are creating JVMElements that are related with the Xcore elements on the fly, add them to the resource and sync them.
So Xbase just uses them without any concern.
Thanks a lot,
Florian
Re: Xcore - magic content assist for XBlockExpression [message #894093 is a reply to message #894081] Fri, 06 July 2012 11:32 Go to previous messageGo to next message
That is in fact the standard Xtext way of creating a JVM language.
For most cases you only have to write a grammar and a JvmModelInferrer
and you're done. You'll get JDT integration for free.
Am 06.07.12 16:50, schrieb Florian Pirchner:
> Hi Ed,
> sync them.
> Thanks a lot,
> Florian
Re: Xcore - magic content assist for XBlockExpression [message #894177 is a reply to message #894093] Sat, 07 July 2012 07:46 Go to previous messageGo to next message
Thanks for the hint. I found the section "Xtext and Java" in the Xtext documentation. Now got an understanding how JVM languages can be built on top of Xtext.
Really great job!
Now i am going to implement a ModelInferrer that allows Xbase to reference my LReferences of EntityModel.
Thanks again for you help.
Best,
Florian
Re: Xcore - magic content assist for XBlockExpression [message #894847 is a reply to message #894177] Tue, 10 July 2012 14:29 Go to previous messageGo to next message
For now i spent many hours browsing the possibilities of the model inferrer.
And i am really impressed.
But i am not sure how to handle "NOT inferred jvm elements". "NOT inferred jvm elements" are elements that do not have any counterpart in the semantic model.
For instance an entity model; and i would like to add a boolean property called "disposed" to the resulting java code.
dsl code:
entity MyEntity {
resulting java code:
public class MyEntity {
private boolean disposed;
This JVMField does not have any counterpart in the semantic model. It is just an implementation detail in the resulting java source code.
My question:
I would like to add the JVMField "disposed" to the JVM-model using the model inferrer. But it will not be related to the semantic model. It is only contained in the JVM model.
Is that good practice or should i use a generator to do such stuff?
I am asking since i did not see any methods in JvmTypesBuilder that can be called without a sourceElement.
Thanks again,
Florian
Re: Xcore - magic content assist for XBlockExpression [message #894849 is a reply to message #894847] Tue, 10 July 2012 14:38 Go to previous messageGo to next message
this should be perfectly solveable in the inferrer.
~Christian
Re: Xcore - magic content assist for XBlockExpression [message #894857 is a reply to message #894849] Tue, 10 July 2012 15:31 Go to previous messageGo to next message
good to know...
Florian
Re: Xcore - magic content assist for XBlockExpression [message #894959 is a reply to message #894847] Wed, 11 July 2012 05:00 Go to previous messageGo to next message
> inferrer.
> the semantic model.
> dsl code:
> entity MyEntity {
> My question:
You can still use JvmTypesBuilder method toField, using as the source
element the entity class
note that the 'disposed' field generated by the inferrer will be visible
and accessible in possible xbase expressions even if it is not in the
original program, if I'm not wrong :)
I did some experiments with the inferrer where the mapping to Java
elements is not direct http://www.rcp-vision.com/?p=4089
hope it helps
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Xcore - magic content assist for XBlockExpression [message #894971 is a reply to message #894959] Wed, 11 July 2012 05:38 Go to previous message
Thanks a lot.
Passing the entity class as the source element will make it really straight forward.
And thanks for your blog too. Very useful!
Florian
Previous Topic:problems with the OnTheFlyJavaCompiler
Next Topic:JVMField with primitive type
Current Time: Mon Nov 03 05:18:47 EST 2025
Powered by FUDForum. Page generated in 0.06216 seconds
