Home » Archived » Jubula » Asterisk as parameter(I have to input a string value with asterisk contained, but Jubula converts * to ()
icon9.gif  Asterisk as parameter [message #893968] Fri, 06 July 2012 05:01 Go to next message
Hi everybody,
In several of my Test Cases I have to input parameters with the wildcard '*' (without ') to my Eclipse RCP AUT.
But everytime I append * to concrete values, Jubula writes it as (.
I got the German keyboard layout and tried English also, but without success. I also tried to escape the * by adding the \ prefix, but this also doesn't work for me.
Interesting is that Jubula also isn't able to write characters like '(' or ')' for me, because this results in totally different characters, too.
Could anyone help? I've already read the manual to solve this issue, but I haven't found anything about this.
Thanks for any replies,
Stefano
[Updated on: Fri, 06 July 2012 05:10] by Moderator
Re: Asterisk as parameter [message #894680 is a reply to message #893968] Tue, 10 July 2012 02:46 Go to previous messageGo to next message
If characters are being entered wrongly, it could be one of two things.
- Either your keyboard layout is indeed incorrect (you can change the layout in the AUT configuration dialog and you should restart the AUT once you've changed it as well as making sure what layout the system is using for the AUT).
That is the most likely cause, but just to be sure - what system are you testing on, and what version of Eclipse / SWT are you using?
HTH,
Alex
Re: Asterisk as parameter [message #894981 is a reply to message #894680] Wed, 11 July 2012 06:32 Go to previous message
Hello Alex,
thank you very much. The hint with the keyboard layout Jubula is working with has worked for me.
I thought Jubula works with the Windows-set layout.
Bye,
Stef
[Updated on: Wed, 11 July 2012 06:32] by Moderator
Previous Topic:Parsing boolean to string
Next Topic:Jubula and passwords
Current Time: Sat Jul 26 07:10:05 EDT 2025
Powered by FUDForum. Page generated in 0.06173 seconds
