Home » Newcomers » Newcomers » Dynamic Help Problem
Dynamic Help Problem [message #892973] Mon, 02 July 2012 04:07 Go to next message
Hi could someone help me out, when I highlight a word (eg String) and choose dynamic help, then choose "Javadoc for 'java.lang.String'" nothing happens, I get a slow green progress bar at the bottom of the screen that slowly loads nothing.
After clicking around, I don't think any of the help links work Sad
Re: Dynamic Help Problem [message #893199 is a reply to message #892973] Tue, 03 July 2012 03:36 Go to previous messageGo to next message
Doesn't anyone have any idea why this is happening?
Does anyone know a better place to get help with this?
Re: Dynamic Help Problem [message #893479 is a reply to message #892973] Wed, 04 July 2012 06:13 Go to previous messageGo to next message
Either the attached Javadoc is not correct, or the browser can't be
found/opened.
Dani
> After clicking around, I don't think any of the help links work :(
Re: Dynamic Help Problem [message #893748 is a reply to message #893479] Thu, 05 July 2012 08:52 Go to previous messageGo to next message
Dani Megert wrote on Wed, 04 July 2012 06:13
found/opened.
Dani
Since I'm using java6u33 I downloaded jdk-6u30-apidocs.zip. Could you tell me how to attach it to eclipse please?
Re: Dynamic Help Problem [message #893930 is a reply to message #893748] Fri, 06 July 2012 02:19 Go to previous messageGo to next message
>> and > choose dynamic help, then choose "Javadoc for
>> 'java.lang.String'" > nothing happens, I get a slow green progress
>> bar at the bottom of the > screen that slowly loads nothing.
>> found/opened.
>> Dani
The easiest way to set up a JRE, is to download the Java [6] SDK, which
also contains the source and then add it via Java > Installed JREs
preference page. After that, verify that your project uses the newly
installed JRE (see project's 'Java Build Path' properties).
If you only want to add the downloaded Javadoc, you select the 'rt.jar'
in the Package Explorer and open its properties. There you can set the
source and Javadoc attachments.
HTH
Dani
Re: Dynamic Help Problem [message #893996 is a reply to message #893930] Fri, 06 July 2012 07:21 Go to previous message
Dani Megert wrote on Fri, 06 July 2012 02:19
>> found/opened.
>> Dani
HTH
Dani
I actually don't think javadoc is the problem, I think Eclipse is set to go online for the docs so It's likely the browser.
So if the browser can't be found or opened how might i determine the exact nature of the problem and fix it?
Previous Topic:Eclipse.exe has stopped working
Next Topic:RCP SDK target unable to run application
Current Time: Wed Jul 23 19:11:30 EDT 2025
Powered by FUDForum. Page generated in 0.08855 seconds
