Home » Modeling » EMF » Edit domain of eclipse not providing the child nodes when product is exported(Edit domain of eclipse not providing the child nodes when product is exported)
Edit domain of eclipse not providing the child nodes when product is exported [message #893746] Thu, 05 July 2012 08:49 Go to next message
Hi all,
I am developing a RCP application which deals with EMF resources. Actually, I am having a xml file for which I am creating a model.
At a particular instant, I am having the root node of the xml file and when i try to get the children of the node using EMF edit domain, it does not return any value and i get 0 children under the root node. But in my xml file, there are 2 children under the root node.
The application works fine, when run from eclipse IDE. But when i tried to export it as a rcp product, the problem arises. What may be the reason for such a behavior when we export it as a product? Is there something, which we should take care of when we export our product for EMF related application.
A help will be greatly appreciated. Thanks in advance.
Girish
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893772 is a reply to message #893746] Thu, 05 July 2012 09:35 Go to previous messageGo to next message
Try running it under debug control to see that the right generated item
provider is being used.
On 05/07/2012 2:49 PM, Girish Chandran wrote:
> Hi all,
> Regards, Girish
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893778 is a reply to message #893772] Thu, 05 July 2012 09:50 Go to previous messageGo to next message
Hi Ed Merks,
How can i debug, when i have exported my RCP as a product. Please guide me how can i debug it in a product mode.
Girish
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893805 is a reply to message #893778] Thu, 05 July 2012 10:27 Go to previous messageGo to next message
Maybe, you forgot to include the resources needed by your product: are the files you are talking about (physically) contained in the final/exported rcp product?
Here is an article on how to remotely debugging a java app:
http://www.ibm.com/developerworks/opensource/library/os-eclipse-javadebug/index.html
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893915 is a reply to message #893805] Thu, 05 July 2012 23:01 Go to previous messageGo to next message
Hi Erdal,
I have added all the resources which are required by the product. I have already got the edit domain by using the file resource. Yes the files are physically present in the exported rcp product. When i try to get the children using the edit domain, it does not show anything, but i was able to get the root node of the xml file.
Girish
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893928 is a reply to message #893915] Fri, 06 July 2012 02:00 Go to previous messageGo to next message
Girish,
If you can't set up remote debugging, you can always resort to adding
print/trace statements to your code. See what type of value is returned
from editingDomain.getAdapterFactory().adapt(root,
IEditingDomainItemProvider.class); it should be your generated item
provider.
On 06/07/2012 5:01 AM, Girish Chandran wrote:
> Hi Erdal,
> Regards,
> Girish
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893948 is a reply to message #893928] Fri, 06 July 2012 03:25 Go to previous messageGo to next message
Hi Ed,
It showing that the adapter factory is undefined for the type editing domain.
Iam using "org.eclipse.emf.edit.domain.EditingDomain". What may be reason for it?
Thanks in advance.
Girish
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893961 is a reply to message #893948] Fri, 06 July 2012 04:35 Go to previous messageGo to next message
Hi Ed,
Currently iam working on a configuration editor development, which is based on ARTOP(It's a consortium of automotive domain tool development). They provide a set of api's. It is also purely based on EMF modelling.
I guess, i internally get items from AUTOSARItemProvider. Will there be any issues with the item provider, which currently I am using? Could you please help to get me out of this problem.
Re: Edit domain of eclipse not providing the child nodes when product is exported [message #893991 is a reply to message #893961] Fri, 06 July 2012 06:58 Go to previous message
Girish,
You're just not providing details sufficient to help with your problem.
It seems clear you've not deployed something, but how can I guess about
that?
On 06/07/2012 10:35 AM, Girish Chandran wrote:
> Hi Ed,
> EMF modelling.
Previous Topic:[CDO] CDO Workspace. On commit 'Change set is outdated'
Next Topic:[Xcore] Problem with a package starting "http://"
Current Time: Mon Sep 01 02:37:34 EDT 2025
Powered by FUDForum. Page generated in 0.52663 seconds
