Migrate XText based RCP to Eclipse 4.2 [message #893740] |
Thu, 05 July 2012 08:38  |
I have an application called Mads that is under Eclipse 3.7 and want to migrate it to Eclipse 4.2 and XText 2.3.
I ended up creating a new project in a new workspace and then manually copying the xtext model and changing all other bits and pieces. It works when i run it as an Eclipse application.
Then I copied the old product and features definition projects and tried to run the product (the application is org.eclipse.ui.ide.workbench).
If I try to run it as a configuration with all installed plugins selected then it runs fine. Then I start de-selecting some plugins, namely so far all b3, epp, egit and buckminster plugins, org.eclipse.e4.tools.*, org.eclipse.wst.* and org.eclipse.emf.codegen.*.
I am still left with a very long list, and the much shorter list from my previous version does not work any more.
I there was documentation / examples / tutorials available that would be most welcome.
MS
Re: Migrate XText based RCP to Eclipse 4.2 [message #910815 is a reply to message #893872] |
Mon, 10 September 2012 08:39  |
Hi Paul & co.
regarding this, is it possible to set up minimal amount of plugins in Eclipse 4, where I have complete Workbench... (common navigator, perspectives, show view menu, show perspective menu, etc...), BUT no JDT support, no PDE support. I was not able to kind of throw java support away from Eclipse 4 based app.
Thanks in advance
Marek
FUDForum. Page generated in 0.03449 seconds
