Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse 3.8 and Apache Batik
Eclipse 3.8 and Apache Batik [message #893436] Wed, 04 July 2012 03:39 Go to next message
at the moment I try to migrate my Eclipse RCP 3.6 application to Juno.
Inside some features of my app I used the Apache FOP framework to
generate diffrent report (xdoc, pdf, html) files.
Even this framework needs the Apache Batik framework in version 1.7.
Until now the are no problem, but with the migration to Eclipse 3.8 as
base framework I run into the problem that Eclipse 3.8 needs also some
batik bundles but restriced it to version 1.6.
Why does Eclipse uses a old version (1.6) of Batik, when the current
version of Batik (1.7) are also mature with release date january 2008???
And how can I handle the issue to uses RCP 3.8 and also FOP?
Greetings
Heiko
Re: Eclipse 3.8 and Apache Batik [message #893860 is a reply to message #893436] Thu, 05 July 2012 13:39 Go to previous message
I don't know how the bundles can co-exist if they're marked as singletons. If they are not marked as singletons, you might be able to install both versions in your application (your own bundles must list a minimum version of 1.7 in order to not be wired up to the 1.6 version).
Upgrade to batik 1.7 is in the list: https://bugs.eclipse.org/bugs/show_bug.cgi?id=266174
Later,
PW
Previous Topic:(Eclipse RCP) How can I add shortcut text after a menu entry in toolbar?
Next Topic:integrate the 3rd party jars into eclipse RCP product
Current Time: Sat Jul 26 06:16:31 EDT 2025
Powered by FUDForum. Page generated in 0.48702 seconds
