Home » Modeling » Papyrus » Problem installing Papyrus 0.9.0.v201207020923
Problem installing Papyrus 0.9.0.v201207020923 [message #893049] Mon, 02 July 2012 08:42 Go to next message
Hello everybody,
I'm trying to install the last version of Papyrus in Juno (0.9.0.v201207020923), but I get the following error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Papyrus Extra Binaries and Sources (Incubation) 0.9.0.v201207020923 (org.eclipse.papyrus.extra.sources.feature.feature.group 0.9.0.v201207020923)
Missing requirement: Papyrus UML Merger (Incubation) 0.9.0.v201207020923 (org.eclipse.papyrus.uml.compare.diff 0.9.0.v201207020923) requires 'bundle org.eclipse.emf.compare.uml2 1.3.1' but it could not be found
Cannot satisfy dependency:
From: Papyrus Extra Feature (Incubation) 0.9.0.v201207020923 (org.eclipse.papyrus.extra.feature.feature.group 0.9.0.v201207020923)
To: org.eclipse.papyrus.extra.uml.compare.feature.feature.group [0.9.0.v201207020923]
From: Papyrus Extra Binaries and Sources (Incubation) 0.9.0.v201207020923 (org.eclipse.papyrus.extra.sources.feature.feature.group 0.9.0.v201207020923)
To: org.eclipse.papyrus.extra.feature.feature.group [0.9.0.v201207020923]
From: Compare UML Feature (Incubation) 0.9.0.v201207020923 (org.eclipse.papyrus.extra.uml.compare.feature.feature.group 0.9.0.v201207020923)
To: org.eclipse.papyrus.uml.compare.diff [0.9.0.v201207020923]
Does anybody have the same problem?
Thanks for your help!!!
Re: Problem installing Papyrus 0.9.0.v201207020923 [message #893054 is a reply to message #893049] Mon, 02 July 2012 08:49 Go to previous messageGo to next message
The recommended version to use is the one provided with the Juno release train (http://download.eclipse.org/releases/juno/), then use the Papyrus discovery site to install extra-features (Help > Install Papyrus Additional Components). You shouldn't have any dependency problem.
However, if you're aware that you're using the Papyrus nightly builds at your own risk, don't forget to check the following option: "Contact all update sites during install to find required software" (Or install EMF Compare from the Juno release update site before you try to install Papyrus Compare Editor).
Camille
Re: Problem installing Papyrus 0.9.0.v201207020923 [message #893059 is a reply to message #893049] Mon, 02 July 2012 08:49 Go to previous messageGo to next message
You are installing post-Juno code, so you will have to work hard to find
the corresponding post-Juno dependencies. Your problem is finiding the
EMF Compare maintence release that is not due for release for another 3
months.
Ed Willink
On 02/07/2012 13:42, Carlos Gomez wrote:
> Hello everybody,
> not be found.
> 0.9.0.v201207020923
Re: Problem installing Papyrus 0.9.0.v201207020923 [message #893062 is a reply to message #893059] Mon, 02 July 2012 08:59 Go to previous messageGo to next message
Ed,
EMF Compare have actually already released their 1.3.1 version (I believe they reused a previous version in Juno, instead of providing an 1.4.0 or 2.0.0, which explains the ".1"). So, there shouldn't be any problem for installing a nightly build of Papyrus here. We're not depending on unreleased builds (yet).
Camille
Re: Problem installing Papyrus 0.9.0.v201207020923 [message #893842 is a reply to message #893062] Thu, 05 July 2012 12:23 Go to previous messageGo to next message
Thanks Camille and Ed,
I'll work with the release version.
Re: Problem installing Papyrus 0.9.0.v201207020923 [message #1021062 is a reply to message #893049] Tue, 19 March 2013 09:03 Go to previous messageGo to next message
I've had the same problem, on eclipse juno sr2.
my solution was to download the latest release from
http://www.eclipse.org/papyrus/downloads/index.php
this was
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/papyrus/downloads/drops/0.9.2/R201302130602/Papyrus-Update-incubation-0.9.2.zip
and in eclipse I went to help->install new software and than i used the archieve and not the url,
after manual installaition it is also possible with help->add papyrus additional components to install furtcher stuff
I hope it helps
Re: Problem installing Papyrus 0.9.0.v201207020923 [message #1774670 is a reply to message #1021062] Wed, 18 October 2017 09:37 Go to previous message
Hi, this topic is old, but it looks like you could have my answer
I tried downloading Papyrus through my proxy, but I doesn't work, so I downloaded archives.
None of the archives I have downloaded contain SysML library.
Is there an archive with the SysML library ?
Thanks for reading !
Maxime
Previous Topic:C++ reverse to UML generation is broken on Oxygen
Next Topic:Static generation of UML-MARTE profile
Current Time: Wed Jul 23 04:25:06 EDT 2025
Powered by FUDForum. Page generated in 0.51105 seconds
