Home » Modeling » TMF (Xtext) » Recursion without recursion?
Recursion without recursion? [message #893033] Mon, 02 July 2012 07:44 Go to next message
Hello everyone,
Ok, I have a problem while defining a dsl where formulas like a * (b / 2) should be written. I get errors all the time and after some hours I don't know how to proceed without help. Does enyone knows what the error message means (see error message below)? Or even better why the errors occur (see code below)? I don't see a left recursion like the ones descriped in the documentation (or in one of the blogs of one of the guys who are responsible for xtext).
The following error message occurs (more than once):
"warning(200): ../org.xtext.scannerdomainmodel/src-gen/org/xtext/example/mydsl/parser/antlr/internal/InternalMyDsl.g:1089:2: Decision can match input such as "'+' RULE_ID" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input"
Here is the relevant part of my xtext-file:
RecalculateFormula:
complexFormula = ComplexFormula
Operant:
parameter = [ParameterWithRecalculate] | integer = INT
SimpleFormulaWithoutBrackets:
leftOperant = Operant (operators += FormulaOperator operants += Operant)*
SimpleFormulaWithBrackets:
'('SimpleFormulaWithoutBrackets')'
SimpleFormularWithOptionalBrackets:
simpleFormularWithoutBrackets = SimpleFormulaWithoutBrackets | simpleFormulaWithBrackets = SimpleFormulaWithBrackets
ComplexFormula:
leftFormula = SimpleFormularWithOptionalBrackets (operators += FormulaOperator formulas += SimpleFormularWithOptionalBrackets)*
I have an additional hint:
When I only use the SimpleFormulaWithBrackets rule instead of the SimpleFormularWithOptionalBrackets rule in the ComplexFormula rule it works. But I want optional brackets!
And: If I want to add the following Rule to the operants again those error messages occur:
Operant:
parameter = [ParameterWithRecalculate] | integer = INT //| double = Double
Double:
predecimalNumber = INT('.'decimalNumber = INT)?
I would be gratefule for any hint.
THX in advance
Hannes
[Updated on: Mon, 02 July 2012 08:10] by Moderator
Re: Recursion without recursion? [message #893060 is a reply to message #893033] Mon, 02 July 2012 08:54 Go to previous messageGo to next message
the short answer is that your double definition would also parse an int (as the decimalNumber part is optional), hence the ambiguity.
Alex
Re: Recursion without recursion? [message #893071 is a reply to message #893060] Mon, 02 July 2012 09:25 Go to previous messageGo to next message
Thx Alexander Smile,
That is logical and without the optional part it works.
But what is with the rules ...
The rule SimpleFormulaWithBrackets starts and ends with brackets. Isn't that a not confusable rule because of the not optional brackets (obviously not - but why)? And how do I get optional brackets?
Thx in advance for any answer,
Hannes
[Updated on: Mon, 02 July 2012 09:29] by Moderator
Re: Recursion without recursion? [message #893141 is a reply to message #893071] Mon, 02 July 2012 16:37 Go to previous messageGo to next message
The second short answer is: Have you looked at the arithmetics example shipped with Xtext or the grammar for XBase. These address the definition of expressions. There are also a couple of blog posts about expressions in Xtext. I guess you have, because you want a non-recursive definition.
By the way, the error is not a problem of left recursion (otherwise the message would say so). It is a problem of ambiguity, i.e. there are several ways to parse the same input (however with a different semantic structure which often is not wanted).
Not looking at the structure of the expressions you parse, does the following help as inspiration?
SimpleFormula: Operant | "("ComplexFormula")";
ComplexFormula: formulas += SimpleFormula (operators += FormulaOperator formulas += SimpleFormula)*;
Alex
Re: Recursion without recursion? [message #893220 is a reply to message #893141] Tue, 03 July 2012 05:22 Go to previous messageGo to next message
Thx again for the inspiration Smile I tried you example - the same errors are rising ...
After trying other stuff I watched the tutorial of Sven Efftinge and the Arithmetics example.
And I tried it out: If you let the example run as it is it works.
But if I try to modifiy the last line of the last rule like this (now a Parameter-reference should be allowed as part of the formula) the same errors arrise again
(code)
Expression:
Addition;
Addition returns Expression:
Multiplication (({Plus.left=current} '+' | {Minus.left=current} '-') right=Multiplication)*;
Multiplication returns Expression:
PrimaryExpression (({Multi.left=current} '*' | {Div.left=current} '/') right=PrimaryExpression)*;
PrimaryExpression returns Expression:
'(' Expression ')' | parameter = [ParameterWithRecalculate]
(errors)
warning(200): ../org.xtext.scannerdomainmodel.ui/src-gen/org/xtext/example/mydsl/ui/contentassist/antlr/internal/InternalMyDsl.g:648:1: Decision can match input such as "RULE_ID" using multiple alternatives: 1, 2
error(201): ../org.xtext.scannerdomainmodel.ui/src-gen/org/xtext/example/mydsl/ui/contentassist/antlr/internal/InternalMyDsl.g:648:1: The following alternatives can never be matched: 2
I don't know what to do anymore Sad
So again I am gratefule for any inspiration ^^
Hannes
Re: Recursion without recursion? [message #893260 is a reply to message #893220] Tue, 03 July 2012 07:50 Go to previous messageGo to next message
I cannot reproduce the problem with my sample code, neither with a quick test of the arithmetic example.
Could you please post the complete grammar.
Alex
Re: Recursion without recursion? [message #893288 is a reply to message #893260] Tue, 03 July 2012 09:14 Go to previous messageGo to next message
Hi and thx for taking the time Smile
Here is the code - as long as I comment out the part "parameter = [ParameterWithRecalculate]" in the PrimaryExpression rule brackets can be set but don't have to (like I want it). The code is more or less copied from the Arithmetics project. But after adding the line the known errors occur ...
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl // ... please think of the URI here - momentary I cannot add links
DomainModel:
{DomainModel}
supportedUsers = SupportedUserStates
supportedProgressStates = SupportedProgressStates
supportedActions = SupportedStateChangingActions
measurementsWithParmeters += MeasurementsWithParametersAndStateTransitions+
SupportedUserStates:
'user states {'supportedUserStates += SupportedUserState (',' supportedUserStates += SupportedUserState)*'}'
SupportedUserState:
name = ID
SupportedProgressStates:
'progress states {'supportedProgressStates += SupportedProgressState (',' supportedProgressStates += SupportedProgressState)*'}'
SupportedProgressState:
name = ID
SupportedStateChangingActions:
'state changing actions {'supportedStateChangingActions += StateChangingAction (',' supportedStateChangingActions += StateChangingAction)*'}'
StateChangingAction:
name = ID
MeasurementsWithParametersAndStateTransitions:
'supported measurements {'measurementsWithParametersAndStateTransitions += MeasurementWithParametersAndTransition 'end measurement;' (measurementsWithParametersAndStateTransitions += MeasurementWithParametersAndTransition 'end measurement;')* '}'
MeasurementWithParametersAndTransition:
measurement = Measurement '{' (parametersWithRecalulate += ParameterWithRecalculate)+ stateTransitions = StateTransitions '}'
Measurement:
'measurement' name = ID
ParameterWithRecalculate:
// new parameter should be declared or know parameter which already has some formulas
(('parameter' name = ID) | ('known parameter' paramWithRecal = [ParameterWithRecalculate]))
'state depending recalculates {' (recalculates += Recalculate)+ '}'
Recalculate:
userState += [SupportedUserState] '&' progressState += [SupportedProgressState]
('&&' userState += [SupportedUserState] '&' progressState += [SupportedProgressState])* '==>' (recalculateFormula = RecalculateFormula | resusedRecalculateFormula = [RecalculateFormula]) ';'
RecalculateFormula:
('reusable formula 'name = ID':')? complexFormula = Expression//ComplexFormula
Expression:
Addition;
'(' Expression ')' | number = Number //| parameter = [ParameterWithRecalculate]
Number:
predecimalNumber = INT '.' decimalNumber = INT
StateTransitions:
'state transitions {' (stateTransitions += StateTransition ';')+'}'
StateTransition:
stateTransitionConditions += StateTransitionContition ('&&' stateTransitionConditions += StateTransitionContition)* '==>' userStateNEW = [SupportedUserState] '&' progressStateNEW = [SupportedProgressState]
StateTransitionContition:
userStateOLD = [SupportedUserState] '&' progressStateOLD = [SupportedProgressState] '&' stateChangingAction = [StateChangingAction]
Re: Recursion without recursion? [message #893384 is a reply to message #893288] Tue, 03 July 2012 15:07 Go to previous messageGo to next message
problem is the rule Recalculate. There is an alternative
a) The first one is a definition of a RecalculateFormula which may be an Expression as the first part ('reusable formula 'name = ID':')? is optonal. However, an Expression may be a an ID (paramter= [ParameterWithRecalculate]).
b) The second is a reference to a RecalculateFormula via an ID.
Hence the ambiguity. The parser cannot decide whether use the recalculateFormula feature or the reuseRecalculateFormula feature when seeing an ID.
The simplest way for disambiguation would be the introduction of a keyword (recalculateFormula = RecalculateFormula | "reuse" resusedRecalculateFormula = [RecalculateFormula]), but this may be impossible if you have no control over the syntax of the language.
Alex
P.S.: White spaces within keywords are not a good idea for several reasons. It may seem nice that you get code completion for "user states {" with one proposal rather than 3, but a) this is what code templates are for where you can even complete the closing bracket in one go, b) your users may not be too happy if they are not even allowed to place the opening bracket on the next line, c) they cause major problems when it comes to lexing (try the follwing model and tell me whether a user will understand the mismatched character error message: "user states { user }"... do you?)
Re: Recursion without recursion? [message #893759 is a reply to message #893384] Thu, 05 July 2012 09:19 Go to previous message
Thx Smile
It works now and I am happy.
The tread can be closed.
PS: And thanks for the hint -> this "user states{user}" effect is - let's say it that way - unexpected
Previous Topic:Cross-reference mistake
Next Topic:Using the AST without eclipse
Current Time: Sun Jul 27 14:38:30 EDT 2025
Powered by FUDForum. Page generated in 0.17935 seconds
