[CDO] Migration [message #893442] |
Wed, 04 July 2012 03:58  |
Does anyone has already proposed or tested to use the functionality of
export/import of a repository for migrate CDO models? The idea would be:
- Export the contents of a repository to an XML file
- Perform a transformation (XSLT for example)
- Import the contents of a repository from the XML transformed file
This may be a simplistic view of things, but it might work for simple
cases of migration.
Thank for your comments.
Another question: Is there a description of the format of the XML file
obtained via the export of a repositoy?
Laurent
Re: [CDO] Migration [message #893691 is a reply to message #893676] |
Thu, 05 July 2012 05:45   |
One could use edapt as frontend to capture meta model changes and translate it to xslt/xquery to execute on the xml files...
Eike Stepper wrote on Thu, 05 July 2012 04:26Am 05.07.2012 10:13, schrieb Maximilian Koegel:
> another possibility to migrate the XML files would be Edapt:
> http://eclipse.org/edapt
I doubt that that would work because the XML files exported directly from a CDO repository are in a proprietary,
scalable format.
Cheers
/Eike
http://www.esc-net.de
> Cheers,
> Maximilian
> Am 04.07.2012 09:58, schrieb Laurent Redor:
>> Hello,
>> cases of migration.
>> Regards,
>> Laurent
Re: [CDO] Migration [message #893696 is a reply to message #893691] |
Thu, 05 July 2012 06:01  |
Am 05.07.2012 11:45, schrieb Erdal Karaca:
> files...
That sounds good ;-)
Cheers
/Eike
>> > Hi,
>> scalable format.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>> > Cheers,
>> > Maximilian
>> >> Hello,
>> >> cases of migration.
>> >> Regards,
>> >> Laurent
FUDForum. Page generated in 0.04921 seconds
