Home » Modeling » EMF » [CDO] Migration
[CDO] Migration [message #893442] Wed, 04 July 2012 03:58 Go to next message
Does anyone has already proposed or tested to use the functionality of
export/import of a repository for migrate CDO models? The idea would be:
- Export the contents of a repository to an XML file
- Perform a transformation (XSLT for example)
- Import the contents of a repository from the XML transformed file
This may be a simplistic view of things, but it might work for simple
cases of migration.
Thank for your comments.
Another question: Is there a description of the format of the XML file
obtained via the export of a repositoy?
Laurent
Re: [CDO] Migration [message #893672 is a reply to message #893442] Thu, 05 July 2012 04:13 Go to previous messageGo to next message
another possibility to migrate the XML files would be Edapt:
http://eclipse.org/edapt
Maximilian
Am 04.07.2012 09:58, schrieb Laurent Redor:
> Hello,
> cases of migration.
> Regards,
> Laurent
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [CDO] Migration [message #893676 is a reply to message #893672] Thu, 05 July 2012 04:26 Go to previous messageGo to next message
Am 05.07.2012 10:13, schrieb Maximilian Koegel:
I doubt that that would work because the XML files exported directly from a CDO repository are in a proprietary,
scalable format.
Cheers
/Eike
http://www.esc-net.de
> Cheers,
> Maximilian
>> Hello,
>> cases of migration.
>> Regards,
>> Laurent
Re: [CDO] Migration [message #893691 is a reply to message #893676] Thu, 05 July 2012 05:45 Go to previous messageGo to next message
One could use edapt as frontend to capture meta model changes and translate it to xslt/xquery to execute on the xml files...
Eike Stepper wrote on Thu, 05 July 2012 04:26
scalable format.
Cheers
/Eike
> Cheers,
> Maximilian
>> Hello,
>> cases of migration.
>> Regards,
>> Laurent
Re: [CDO] Migration [message #893696 is a reply to message #893691] Thu, 05 July 2012 06:01 Go to previous message
Am 05.07.2012 11:45, schrieb Erdal Karaca:
> files...
That sounds good ;-)
Cheers
/Eike
>> > Hi,
>> scalable format.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>> > Cheers,
>> > Maximilian
>> >> Hello,
>> >> cases of migration.
>> >> Regards,
>> >> Laurent
Previous Topic:EMF decorators
Next Topic:Model Change Notification, Adapters, GEF, ArrayStoreException
Current Time: Wed Jul 23 11:39:53 EDT 2025
Powered by FUDForum. Page generated in 1.04216 seconds
