ArrayIndexOutOfBoundsException [message #893614] |
Wed, 04 July 2012 18:25  |
Has anyone seen this before when creating a TitleAreaDialog?
Wim
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.rwt.internal.theme.AbstractThemeAdapter.getPrimaryElement(AbstractThemeAdapter.java:40)
at org.eclipse.swt.internal.widgets.controlkit.ControlThemeAdapter.getFont(ControlThemeAdapter.java:47)
at org.eclipse.swt.widgets.Control.getFont(Control.java:661)
at org.eclipse.rwt.widgets.Upload.computeBrowseButtonSize(Upload.java:368)
at org.eclipse.rwt.widgets.Upload.computeSize(Upload.java:302)
at org.eclipse.swt.layout.GridData.computeSize(GridData.java:482)
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:209)
at org.eclipse.swt.layout.GridLayout.computeSize(GridLayout.java:154)
at org.eclipse.swt.widgets.Composite.computeSize(Composite.java:563)
at org.eclipse.swt.layout.FormData.computeSize(FormData.java:118)
at org.eclipse.swt.layout.FormData.getWidth(FormData.java:147)
at org.eclipse.swt.layout.FormLayout.computeWidth(FormLayout.java:267)
at org.eclipse.swt.layout.FormLayout.layout(FormLayout.java:322)
at org.eclipse.swt.layout.FormLayout.computeSize(FormLayout.java:231)
at org.eclipse.jface.window.Window.getInitialSize(Window.java:608)
at org.eclipse.jface.dialogs.Dialog.getInitialSize(Dialog.java:1174)
at org.eclipse.jface.dialogs.TitleAreaDialog.getInitialSize(TitleAreaDialog.java:352)
at com.remainsoftware.incidents.ui.dialog.updateIncident.UpdateIncident.getInitialSize(UpdateIncident.java:320)
at org.eclipse.jface.window.Window.initializeBounds(Window.java:780)
at org.eclipse.jface.dialogs.Dialog.initializeBounds(Dialog.java:699)
at org.eclipse.jface.window.Window.create(Window.java:448)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1071)
at com.remainsoftware.incidents.ui.dialog.updateIncident.UpdateIncident.create(UpdateIncident.java:79)
at com.remainsoftware.incidents.handlers.UpdateCall.execute(UpdateCall.java:70)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:306)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:167)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:239)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:843)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:819)
at org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatchEvent(UntypedEventAdapter.java:646)
at org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetSelected(UntypedEventAdapter.java:90)
at org.eclipse.swt.events.SelectionEvent.dispatchToObserver(SelectionEvent.java:191)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.java:46)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.java:186)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.java:208)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1135)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at com.remainsoftware.rap.application.Application.createUI(Application.java:36)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:177)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:289)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
2012-07-05 00:04:36.027:WARN:oejs.ServletHandler:ERROR: /remain
at org.eclipse.rwt.widgets.internal.uploadkit.UploadLCA.renderChanges(UploadLCA.java:141)
at org.eclipse.rwt.lifecycle.AbstractWidgetLCA.render(AbstractWidgetLCA.java:35)
at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$RenderVisitor.render(DisplayLCA.java:88)
at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$RenderVisitor.doVisit(DisplayLCA.java:72)
at org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidgetTreeVisitor.visit(WidgetTreeVisitor.java:31)
at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(WidgetTreeVisitor.java:62)
at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.handleChildren(WidgetTreeVisitor.java:122)
at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(WidgetTreeVisitor.java:52)
at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.renderShells(DisplayLCA.java:194)
at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.render(DisplayLCA.java:164)
at org.eclipse.rwt.internal.lifecycle.Render.execute(Render.java:29)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLifeCycle(RWTLifeCycle.java:158)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLifeCycle.java:229)
at org.eclipse.swt.widgets.Display.sleep(Display.java:1176)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(WorkbenchAdvisor.java:361)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2734)
FUDForum. Page generated in 0.09395 seconds
