Home » Eclipse Projects » Eclipse 4 » Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access
Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #892633] Thu, 28 June 2012 16:42 Go to next message
Just starting to test out an RCP app we have from Eclipse 3.7 to Eclipse 4.2.
In our 3.7 RCP app, the perspective bar loads on the top-left (where we want it)
Under 4.2:
a) the perspective bar is now on the top-right (undesired in our case)
b) the Quick Access search bar is there, but we don't want it - what contributed it there?
thank you!
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #892981 is a reply to message #892633] Mon, 02 July 2012 04:26 Go to previous messageGo to next message
Unfortunately, we're facing the same problem when trying to fire up our eclipse 3.7 based RCP-App from within eclipse 4.2. Furthermore there is some "empty space" before any toolbar-entries start.
And last but not least: We've an intro-site that popped up full-screen with eclipse 3.7. It is now shown as you can see in the attached image. Furthermore when closing the intro/welcome-page, the space on the right hand is not "recycled" and is that way wasted during all time.
Any hints would be highly appreciated,
Johannes
[Updated on: Mon, 02 July 2012 04:28] by Moderator
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #893489 is a reply to message #892981] Wed, 04 July 2012 06:42 Go to previous messageGo to next message
I suggest putting the e4-tools in your target platform and to use the
live-model editor (Alt+Shift+F9) to debug the workbench model while the
application is running via the show-control function in the widget tree..
Am 02.07.2012 10:26, schrieb Johannes Michler:
> Unfortunately, we're facing the same problem when trying to fire up our eclipse 3.8 based RCP-App from within eclipse 4.2. Furthermore there is some "empty space" before any toolbar-entries start.
> And last but not least: We've an intro-site that popped up full-screen with eclipse 3.8. It is now shown as you can see in the attached image. Furthermore when closing the intro/welcome-page, the space on the right hand is not "recycled" and is that way wasted during all time.
> Regards,
> Johannes
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #893492 is a reply to message #892981] Wed, 04 July 2012 06:47 Go to previous messageGo to next message
and obviously you are missing the SWT-Addons for e4-compatibility....
> Regards,
> Johannes
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #893494 is a reply to message #892981] Wed, 04 July 2012 06:47 Go to previous messageGo to next message
> Regards,
> Johannes
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #895453 is a reply to message #893494] Fri, 13 July 2012 01:07 Go to previous messageGo to next message
Did you guys got the proper solution to this?
i.e. how to remove the quick access bar from rcp app.
If yes please post it here..!
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #895901 is a reply to message #895453] Mon, 16 July 2012 09:10 Go to previous messageGo to next message
That's https://bugs.eclipse.org/bugs/show_bug.cgi?id=362420
PW
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #895903 is a reply to message #895453] Mon, 16 July 2012 09:12 Go to previous messageGo to next message
Could you put together a sample application that demonstrates this issue?
The solution is to create a lifecycle processor that removes the necessary components. I would be happy to put together a processor that does this if there is a sample app.
JD
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #896481 is a reply to message #895903] Wed, 18 July 2012 09:56 Go to previous messageGo to next message
Joseph Carroll wrote on Mon, 16 July 2012 09:12
Steps to reproduce problem:
Open eclipse 3.8 and create two RCP applications from templates:
1. RCP with view
2. RCP email
Open this workspace in eclipse 4.2
You can see not designed "Quick access" in both of this applications: Quick access + additional not designed toolbar.
When I open my Eclipse RCP application in 4.2 I see same not designed toolbar (see attachment).
Please help remove this elements.
Thank you.
[Updated on: Wed, 18 July 2012 09:57] by Moderator
Re: Toolbar for RCP apps: change location of perspective bar, remove/move Quick Access [message #896483 is a reply to message #896481] Wed, 18 July 2012 09:57 Go to previous message
index.php/fa/10751/0/
problem in hardcoded line: void populateTopTrimContributions() {
trimBar.setToBeRendered(true);
have to be replaced with something like: private boolean getShowHeapStatus()
And for compatibility WorkbenchWindowAdvisor have to be used for removing this trim bar in classic RCP applications.
setShowCoolBar(false) doesn't allow remove this trim bar.
see sample:
public void preWindowOpen() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setShowCoolBar(false);
[Updated on: Wed, 18 July 2012 10:49] by Moderator
Previous Topic:CSS & DI
Next Topic:Dragging Views & Editors
Current Time: Wed Jul 23 17:01:14 EDT 2025
Powered by FUDForum. Page generated in 0.08257 seconds
